Re: T5 leaking from bellhousing
I'm not crazy about dropping the trans again to replace the input shaft seal, so I'll probably try using gear oil. the only reason I used the Dexron III was because that's what my Haynes and Chiltons recommended. The fluid that came out of it was red, but seemed much thicker. Didn't smell burned or anything. If it's the seal, I'd guess I wrecked it while installing the trans after replacing the clutch. Tough to imagine though since I installed the engine & trans in one piece. Any other thoughts or suggestions?
