Front Track Bar - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-10-2000, 11:16 PM Thread Starter
Journeyman
Front Track Bar
My 99 TJ has a ProComp 4" Stage 2 lift. The problem is the track bar lowering bracket combo doesn't allow the use of an aftermarket steering stabilizer or skid plates etc. I would like to replace the track bar with another one but I had to drill the frame mount hole to 9/16" for the bracket. Most of the bars I have seen still have the tappered end. Any help or suggestions would be appreciated.
Mudman99TJ is offline
post #2 of (permalink) Old 09-10-2000, 11:43 PM
Re: Front Track Bar
The Rubicon Express front track bar uses a completely different mounting bracket at the frame. It has a ball joint that allows for more movement. I run a rancho steering stabilizer with this set up.
Axlesupagain[img]/wwwthreads_images/icons/crazy.gif[/img]
98 TJ 6.25" lift, 35" BFG's D44/D30 detroits,
96 XJ 4.5" lift, 31"BFG's 8.25/D30,lockright
http://home1.gte.net/lrgreen2/index.htm
post #3 of (permalink) Old 09-11-2000, 02:26 PM Thread Starter
Journeyman
Re: Front Track Bar
Did you have to drill out the factory bracket and if so to what size?
Where's the Mud
post #4 of (permalink) Old 09-11-2000, 05:02 PM
InfantryYJ's Avatar
Re: Front Track Bar
I got the Rubicon Express track bar for my XJ and it does not have the tapered end where it mounts to the frame. If I remember correctly I had to drill out the mounting bracket to 9/16". Give them a call to be sure.
I may not like what you say, but I'll defend to the death your right to say it.
Semper Jeep
InfantryYJ is offline
post #5 of (permalink) Old 09-13-2000, 02:40 PM Thread Starter
Journeyman
Re: Front Track Bar
Has anyone else had this problem with a Pro-Comp track bar or used a track bar with a 9/16" frame end bolt or any other aftermarket track bar that requires drilling the frame mount hole larger.
Where's the Mud
post #6 of (permalink) Old 09-19-2000, 05:20 PM Thread Starter
Journeyman
Re: Front Track Bar
One more try.
Where's the Mud
