Pinion angle and lift kit Question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-03-2000, 10:58 PM Thread Starter
Smokngun's Avatar
I am ordering my 2.5" springs for my CJ-7 soon and was pondering the reason that all lift kits seem to come with degree wedges attached to the rear springs. I know this is to "correct" pinion angle on the lifted Jeep, but if the rear pinion and t-case yoke are supposed to be parallel to each other, and you are lifting the Jeep straight up, dont they remain parallel? If so, why the degree wedges? If not, then ...well...why not?
This isn't an emergency question, just an engineering one that I cant figure out. Thanks! (I know this is going to be a simple one and I'm gonna' look realy stupid, so please no flames...OK...please.)
Mike H.
<font color=blue>1983 CJ-7 Laredo</font color=blue>
2000 Durango SLT
I can't go to work today...the voices said "Stay home and clean your guns!"
Smokngun is offline
post #2 of (permalink) Old 09-03-2000, 11:05 PM
Re: Pinion angle and lift kit Question
Most 2.5" springs DON'T come with degree wedges. They shouldn't be necessary with that lift. I've had 2 different brand 2.5" kits in my Jeep, Rancho and Pro-comp, neither came with nor needed correction.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #3 of (permalink) Old 09-04-2000, 11:19 AM Thread Starter
Smokngun's Avatar
OK, but the Skyjacker kit that we put on my bosses YJ (2") had wedges. I think they were something like 2 or 4 degrees.
Mike H.
2000 Durango SLT
Smokngun is offline
post #4 of (permalink) Old 09-04-2000, 06:29 PM
A GUESS: For those running a CV drive shaft. In that case you would have to rotate the axle toward the higher t/c output shaft, but I can see the reason for your question. If you raise the frame straight up, it does seem that the pinion and T/C output shaft would retain their parallelism. Parallel works with a U-joint at each end, but not a CV joint at one end.
Doug '97 TJ
Creator of the CBrack
http://www.CBrack.com
