Wedge Plates for 75 CJ - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-03-2000, 03:26 PM
Where can I find axle/spring wedge plates for a 75 CJ5??
Thanks
Everyday travel is off-roading in this town....
post #2 of (permalink) Old 09-04-2000, 02:10 AM
Re: Wedge Plates for 75 CJ
MTJeeper
I got a wrangler pair from four wheel drive hardware, and I cut the sides down to size on a metal band saw. They have worked great for 2 years now.
GOOD LUCK
MADD MUDDER
post #3 of (permalink) Old 09-04-2000, 02:47 PM
Check the Samuri board. They run 2" springs also.
Keith
C-Ya.....................kh
Junkfood is offline
post #4 of (permalink) Old 09-04-2000, 06:03 PM
Whatever wedge plates you use, make sure they are steel, and use the spring center bolt to bolt them to the spring. I made the mistake of useing aluminum wedges, they would wear, and the U-bolts would lossen up, I rolled my Jeep because of this. I pulled the wedges out the first chance I got. Still drives fine just hard to flat tow, and from your previous post, I am assuming that is why you want the wedges. Another option is offset upper ball joint bushings. They will only give you up to 2 degrees, but it might be enough to make it flat tow allright.
Thanks, Ray
