It worked! plug in delay wipers for late CJ's - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-03-2000, 04:25 AM Thread Starter
It worked! plug in delay wipers for late CJ\'s
It all started while thumbing thru a 4wd hardware catalog. They listed a delay wiper switch for 83-86 CJ's. I checked around and, yes, it was an option. From what I could find out you had to have a 4 wire wiper motor. I checked our 83, and sure enough it did. Now, the switch is listed for almost 55 bucks. WHEW! So while in Denver visiting my brother I go to a local salvage (what do you do on vacation?) and look around for a switch. Lo and behold, they were all over! Nearly every older fullsize wagoneer and Jeep Eagle I looked at had one! Look for a 82-86 model. You need to get the switch, which has a white ground wire riveted to it, and the wire harness and control box. One end of the wire harness plugs into the (delay)switch, the other end plugs into the connector that normally goes to the non delay switch on a non delay setup. There is a plastic control box in the middle. So all you have to do is unplug the old switch, plug in the harness, and ground the white wire hanging off the switch. Viola, delay wipers! Everything functions as it did, except you turn the switch counter-clockwise to operate the delay. Delays between 8 and 25 seconds. I also looked at an early 80's Bronco, the dash was stripped but the connector to the (missing) wiper switch was the same, control box and everything. Although I don't know, I would guess an older CJ with a 3 wire motor would have to switch to the 4 wire motor. I picked up a second switch and harness for my buddies 82, he doesn't know if he has a 3 or 4 wire motor, will post results when they are in.
Greg
89 XJ-stock, 83 CJ-7/4.0HO-t18-d300-locked-2.5" rancho-32 bfg mt, 79 Blazer/454-t400-np205-locked-4w disc-35 bfg mt, 67 CJ-5/231-t18-d18-4.88-front disc-rear 11" drum/front locked/30-9.50's
schardein is offline
post #2 of (permalink) Old 09-03-2000, 12:13 PM
Re: It worked! plug in delay wipers for late CJ\'s
One big pat on the back for you for posting this info. It`s been copied and pasted in my Project CJ folder and I WILL be doing this upgrade . Thanks !!!
Jeff
<font color=red>
Happy Owner of a 1979 CJ5
Almost finished [img]/wwwthreads_images/icons/tongue.gif[/img] ( Ya Right ! )</font color=red>
<font color=blue>There`s No Such Thing As Surface Rust</font color=blue>
Jeepzilla is offline
