Replacement for AMC 20 rear axle - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-31-2000, 11:42 PM Thread Starter
It seems that my friend just nuked his AMC20 axle. We haven't had time to take it apart but there are some big dents from the inside out on the diff cover. Depending on how bad it is how expensive is it to get new gear or to replace the whole axle. He was also wondering how much it might be to swap something else under it like a Dana 44 or something. By the way it is a '79 CJ7. Thanks.
Josh Lavalleur
'70 CJ5 4.3L V6
D27 & D44 axles
T-14 3-speed, D18 XC, Warn OD
Ulfinator is offline
post #2 of (permalink) Old 09-01-2000, 07:07 AM
Re: Replacement for AMC 20 rear axle
Scout 44 is a bolt in with the same bolt pattern. Only thing needed is to move the perches. For info go to: http://www.jeeptech.com/convaxle/
Boston Mangler
CJ7, T18, Dana20, Scout 44's F&R, Detroits F&R, 4:56 Gears, SOA, Hi-Steering, York, etc...
post #3 of (permalink) Old 09-01-2000, 07:57 AM
I Do This For The Glory
JEEPN's Avatar
What gear ratio is it?
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7" Lift/33" Swampers/REP 8000/RS9000's/Scout II D44's F&R w/4.10's & Lockrights
JEEPN is offline
post #4 of (permalink) Old 09-01-2000, 08:04 AM
your buddy is probably gonna need a gear set + set up for sure ( approx $400-$600)
if you find a dana 44 that doesnt have the right gear set your gonna be out the same money to change gear ratios plus the cost of hte axle.
the only really bad things about the AMC20 is are the 2 pc axles ( a kit can fix this) and the weak housing/tubes ( which can be fixed by welding)
it just depends on what extent its damaged and what he wants to spend.
the cheapest and easiest thing would be to find another stock Jeep axle, with the same gear ratio and use it until it breaks.
OzarkJeep
"Too small to be seen, and too big to control, and treated like a walking bomb."
ozarkjeep is offline
post #5 of (permalink) Old 09-01-2000, 02:16 PM Thread Starter
Not sure what the gear ratio is offhand. I will have to go over and figure that out. He bought it just a little while ago as his first Jeep.
Josh Lavalleur
'70 CJ5 4.3L V6
D27 & D44 axles
post #6 of (permalink) Old 09-02-2000, 12:48 AM
The Scout axle, even though it has the same bolt pattern, is about 8 inches wider. It isn't a bad swap if you do the front also. It might look a little strange with a widder rear track. My suggestion would be a Wagoneer front, it is a easier swap than a Scout front, more caster, to go with a Scout rear. If you go trough all that trouble, you might as well go full width 3/4 or 1 ton hardeware. It wouldn't cost much more, and you get wider axlez ( more stable ) and a stronger rear end, stronger front if you go 1 ton. One more option would be a 9 inch Ford out of a early Bronco, same bolt pattern, but still to wide if you don't swap the front. I still havn't made up my mind, but I am leaning towards a 1/2 ton Ford 9 or 8.8 inch rear, and a GM D44 front, converted to my CJ brakes and hubs.
Thanks, Ray
post #7 of (permalink) Old 09-19-2000, 07:39 PM Thread Starter
Turns out a guy in Spokane had an almost new Dana 44, solid axles limited-slip that he was willing to part with. After dealing with spring plates without shock studs and holes in the spring perches being to small it is in and working awesome...
Josh Lavalleur
'70 CJ5 4.3L V6
D27 & D44 axles
