CLeaning Throttle Body - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-04-2000, 01:03 PM
Wrangler88
What can u I use to really clean out the TB on my 95 wrangler?
thanks!
(\/)ikey 1988 Wrangler Laredo 4.2L w/5spd Manual
1995 Wrangler 2.5L w/ 5spd Manual
post #2 of (permalink) Old 01-04-2000, 02:26 PM
Re: CLeaning Throttle Body
Get some Throttle Body cleaner from your local autoparts store, should be right with the carb cleaner. To do it really good take off all the sensors from it (and get a new gasket) and clean it up off of the intake. On the Idle stepper motor make sure and not damage the pintle, just wipe it clean of oil/dirt. Usually take me about 30 min. or so (when I want to get it sparkling!)
Good luck!
rlm93yj
http://members.xoom.com/RLMYJ/JEEPYJ.htm
post #3 of (permalink) Old 01-04-2000, 07:28 PM
I think that the absolute best stuff is the Mopar combustion chamber cleaner. This stuff is 70% water, and uses amonia for the cleaning agent. Warm the engine up real good, and just spray it down the throttle plates and into the idle air passages with the motor running at idle. It will want to run rough, and move the idle air control out and in, which helps get a better cleaning action. As it goes into the combustion chamber, it will turn to steam, and clean off any carbon and olifins that accumulate. When the can is about 3/4 empty, shut off the key, and fill the throttle plates to the top to soak for about 5 minutes. Now spray some more down the throttle and scrub it with your fingers. Then start the engine, and run the rest of the can through. RE-attach the air cleaner and drive it down the highway until it quits smoking.
This stuff is great! It will raise compression by freeing up rings, and will also cure the carbon knock that is assocoiated with high mileage 4.0's and 4.2's.
One other thing. It will not carbon foul plugs, as normal carb cleaner will. You should never do this with carb cleaner!
dorfs is offline
post #4 of (permalink) Old 01-05-2000, 12:07 AM
Wrangler88
thanks for the info, anyone else try that mopar cleaner stuff, and how much is it and where can u get it?
