roll cages - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-24-2000, 08:13 AM
roll cages
It seems most of you design your own roll cages,is there a reason for this?I've tried to find a kit from the racecar guys(art Morrison,ect.)with no luck.Any suggestions?I have access to a tig welder,fishmouth tool,ect.,but how do you bend the pipes to conform to dash?I've seen street rods with the side bar hinged to allow easier entry(my buddy says no way!but he just likes to laugh at my fat [email protected]# trying to get in and out)is this a no no?My buddy has built several chassis cars,and will do all the real work,but rather than just hand it to him,i'd like to learn the ins and outs(and not appear totaly stuip!)
Matt
all laws only affect the law abiding
support capital punishment,guarantee no repeat offenders
post #2 of (permalink) Old 08-24-2000, 09:08 AM
Re: roll cages
[img]/wwwthreads_images/icons/smile.gif[/img] The reality, Matt, is that there doesn't seem to be any one-design-does-it-all ROPS [Roll Over Protection System] that is available as aftermarket. Everybody wants something a little different. Yesterday it occurred to me that I could build a cantilevered setup and not sacrifice the dashboard area. I noticed a power roller on a paving job that was built that way, and I am really thinking about doing that. The bending will have to be done by an ace bender-guy, but if I choose tube that is the same O.D. as say...2-1/2" or 3" standard pipe, I know a lot of industrial electricians who can bend with great precision. The other thing I could do is use SQUARE tubing; and forget the difficulty of making precision bends. Square tube is stronger, pound for pound, and that is exactly what the heavy equipment companies use. A setup like that COULD be aftermarketed, because it would mount nearly the same as the stock CJ bar does.[img]/wwwthreads_images/icons/crazy.gif[/img]
CJDave
CJDave is offline
post #3 of (permalink) Old 08-24-2000, 09:31 AM
Re: roll cages
i've often wondered why square tubing is not used.
dave, you say that it is stronger # for #. what might the downfalls be?
harder to bend?
weaker joints (no fishmouths, just square-ups)?
heavier?
more expensive?
anyone?
tj
[img]/wwwthreads_images/icons/cool.gif[/img] "it was a '76, '77, '78, '79...'83 automobile!" (johnny cash)
post #4 of (permalink) Old 08-24-2000, 10:39 AM
Re: roll cages
Well, the obvious reason would be if you were to knock your head on it. The corner would deliver the full force of impact to a small area of bone. Granted, a round tube isn't much better. But, it would make the difference between a goose-egg and a cracked skull.
post #5 of (permalink) Old 08-24-2000, 12:38 PM
Re: roll cages
dave, is this somewhat what you're talking about as far as a "halo" design? using something like 3 inch tubing> granted, not as cool as 304's designs, but you get the picture.
tj
post #6 of (permalink) Old 08-24-2000, 12:48 PM
Re: roll cages
damn! forgot to attach.....
tj
post #7 of (permalink) Old 08-24-2000, 12:51 PM
Re: roll cages
[img]/wwwthreads_images/icons/smile.gif[/img] Ok Maybe this is a stupid question but, what exactally is a fishmouth tool? I think I pretty much know what it does(not all that dumb).But how does it work? Where do you get one? And for how much $$.Thanks.Kyle
If you can't break it, Try Harder[img]/wwwthreads_images/icons/cool.gif[/img]
79 CJ-7/304/T-18/Dana20/No tires(yet)/rust[img]/wwwthreads_images/icons/frown.gif[/img]
[email protected]
post #8 of (permalink) Old 08-24-2000, 01:39 PM
Re: roll cages
[img]/wwwthreads_images/icons/smile.gif[/img] Yep....that's it, except you IMPROVED IT with the lower horizontals.....I hadn't thought of that.....nice shot![img]/wwwthreads_images/icons/smile.gif[/img]
CJDave
CJDave is offline
post #9 of (permalink) Old 08-24-2000, 01:45 PM
Re: roll cages
[img]/wwwthreads_images/icons/tongue.gif[/img] It must be some sort of cutter or maybe a pattern that is used to mark the pipe so you can fit up a nice "T" joint. I have patterns which I can only use for the little stuff.....under 4"..... whereas cool, welder-fitter guys like me mark the large diameters with a contour marker, a crab, a center head, and a snapline.[img]/wwwthreads_images/icons/cool.gif[/img] So often you are going with different diameters, so patterns won't work. If you can do it from scratch, the difference in diameters on branching tees and the less-than-90-degree angles are no problemo.[img]/wwwthreads_images/icons/crazy.gif[/img] Hey.....do I BRAG...or what? I hope Jo-Jo isn't reading this[img]/wwwthreads_images/icons/blush.gif[/img]
CJDave
CJDave is offline
post #10 of (permalink) Old 08-24-2000, 01:56 PM
Re: roll cages
[img]/wwwthreads_images/icons/smile.gif[/img] Can you make a separate post with this attachment? Maybe title it the "NEW" ROPS. [Roll Over Protection System] Show that setup. Make a note that the lower horizontals punch through the floor and connect to the CJ frame mounts just above the rubber buscuit. This design really has some merit, especially now with the lower horizontals.[img]/wwwthreads_images/icons/smile.gif[/img]You can call this the "C" cab design...first because it resembles the early Ford (model T era) open cab trucks, and second because it is a "cantilevered design".[img]/wwwthreads_images/icons/smile.gif[/img]
CJDave
CJDave is offline
