1987 XJ tranny to YJ options? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-23-2000, 08:50 PM
Okay here goes...last time I'm posting on this topic....I hope. =)
I've been searching high and low for a trannsmission replacement for my 1987 Wrangler, 4.2 liter, currently has a 5 speed tranny. Cheapest I've found one is for $800 without labor!
Here are my questions, please help if possible....
Can I swap a tranny into my YJ from a cherokee from the same year? The cherokee would be a 4wd, 4.2 liter as well. I have the following options. An automatic for $330, a 4 speed MT for $500, and a 5 speed MT for $1100! I can't believe the prices on the five speeds. Anyhow....will all these trannies be a direct swap, and will they match my transfer case? I'm steering toward the 4 speed, so I guess I will ask, is the 4 speed in a cherokee a hydraulic clutch? I ran into that problem because I was going to swap in a t4, but my mechanic wouldn't do it, because it was a cable clutch.
Any help and answers will be greatly appreciated. if the auto will work, I can do that myself as I've swapped in autos before, I'm just leary of putting an auto into a vehicle that has a standard. Clutch peddles and all. Besides, standards are a lot more fun.
post #2 of (permalink) Old 08-27-2000, 03:34 PM
Re: 1987 XJ tranny to YJ options?
All XJs, '87 and newer use the 4.0L, not the 4.2. The 4.0l XJ trans fits the 4.2L, but the rear extension housing has different clocking for the t-case. The Automatic trans from an XJ 4.0 is a AW-4 overdrive that would require extensive rewireing and swapping the EFI off the 4.0 to work. There never was a 4.0XJ or a 4.2YJ with a 4 speed from the factory. The XJ has the same poo-geot BA10-5 as the YJ, with the exception of the extension housing. There is no advantage to this swap.
Your best bet would be to find a AX15 out of a '91 YJ, and the t-case to go with it. The 231 t-case has better internals than the 207 most '87s have, and the AX 15 is stronger than the BA10-5. The option for an automatic is either a 999 out of a YJ, CJ or Eagle car, or a 727 out of a Wagoneer. Either will require a shifter and a change of input gears in the t-case.
Hope this helps, good luck!
