YJ Brake Bleeding - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-29-1999, 07:34 PM
YJ Brake Bleeding
I just completed lifting my 89' YJ with a skyjacker 2 inch lift kit. When
I finished the lift, I noticed that the brake lines needed to be replaced. I
bought skyjacker brakelines for the front and back. The back lines blead fine, however the front passenger does not have a continous flow of brake fluid when I attempt to bleed them with a vaccuum pump. The front drivers side just shows air (no fluid being pumped). The fluid level is fine. I also loosened the brake line to the caliper on the drivers side and it does drip brake fluid --- so the line should be ok. I noticed that the brake lines are not identical to the original YJ's -- the caliper's are connected with a rectangluar brass block to the brake line (the originals were a 3/4 circular block with a flat side). Has anyone had a simular experience?? I'll call sykjacker tommarrow, but I'm hopping to get the jeep on the road sooner...
Thanks!!!
post #2 of (permalink) Old 12-29-1999, 08:58 PM
Re: YJ Brake Bleeding
<font color=blue>Yes, I had the same concerns. The aftermarket steel lines connect to the brake with a different end, but work the same. I haven't had any problems with mine... It was my first time bleeding, too... I replaced mine with Goodridge or something... (so many parts, so little time!)[img]/wwwthreads_images/icons/wink.gif[/img]
<font color=blue>Jon-YJ94
<font color=red>a work in progress
[email protected]
