control arms - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-28-1999, 08:59 AM
Landon
control arms
i have a 97 tj and it has some driveline vibrations. I tried playing around with t-case height and couldn't get it to go away, now I want to try some control arms. Can i get away with just the lower arms. Where can i get some for cheap. I've heard the Tera-flex's are about $199, does anybody know if one can order from them direct?
Thanks for the help
post #2 of (permalink) Old 12-28-1999, 12:00 PM
Re: control arms
What size lift are you running?
I dont think you can order from Tera directly but try http://www.mepco4x4.com instead.
LarryM
85 CJ7, 350TBI ,T19 4spd
'00 TJ Sport, NV3550 5spd, D44, Teraflex system
post #3 of (permalink) Old 12-28-1999, 01:26 PM
Re: control arms
A little advice....and this is speaking from experience. Even if you play around with t-case and leaf shims to get the drive shaft angle correct, it will still give you some vibration either on accel or decell....trust me, save your self some time and labor...buy the CV drive shaft from someone like 6 States Distributors. Its one of the best mods I made. The only allignement you have to worry about then is making sure the diff is point straight up the drive shaft. It also means you can put your t-case all the way up giving you more ground clearance.
Let me repeat....This is [b]'experience' talking.............
John......southern CA
84CJ7,3"lift,32"BFG,4.11's,ARB,Solid Axle's
post #4 of (permalink) Old 12-28-1999, 03:15 PM
Re: control arms
John,
He is talking about a TJ. No leaf springs to be shimmed.But I agree with you... unless you went with a SYE you there will be some type of vibrations on a lifted TJ. You may not be able to feel them but they are there and driveline failure will happen one day.
I'd do the JB Converions SYE plus a Tom Woods CV driveshaft. In order to use the CV you will need to adjust your pinion and that would call for adjustable control arms.... gets expensive doesnt it? And while you are at it, might as well install the new "Belly-Up" kit from Tera... this will free up an additional two inches over stock.
LarryM
post #5 of (permalink) Old 12-28-1999, 06:27 PM
Re: control arms
Larry,
I guess i need to look at a TJ then....I thought they had leafs in the rear...
By the way...my CJ is still running great with the HEI mod...I was even able to adjust the vac advance to get the ping out.
84CJ7, 3"lift, 32"BFG, 4.10's, ARB Locker, Solid Axle's, Durabak
post #6 of (permalink) Old 12-29-1999, 12:04 PM
Re: control arms
TJ's are coil all the way.
Several ways to attack your problem, but it helps to plan your mods to fit with future mods so that you don't have to buy the same thing over and over again.
1) Adjustable control arms.
A good investment. One that will work with lots of different setups and can be adjusted when new mods make angle changes necessary. You can get by with adjustable arms on bottom only, but if you put them on top and bottom, it gives you more control on positioning the axle from front to rear as well as rotating it. When you shorten lower control arms, that causes the pinion to roll upward, but it also shortens the wheel base a bit. This becomes a problem with larger tires, 35's, because the tire will hit the front of the fender well at the bottom corner (rear axle). By lengthening the arms you can move the axle rearward and clear the corner and still keep the rotation where it is supposed to be.
2) Off set bolt (cam action) in frame end of the (lower, I think) control arm.
Jeep sells a bolt that has a cam action so that as it is rotated it moves the front of the control arm to the front or rear thus rotating the axle a bit. This is a cheap fix as opposed to the adjustable control arms, but it has a very limited range. Am not sure whether it is the upper or lower arm that takes this bolt. Lower, I think, but might even be able to put it in both. You need to check this out if it is of interest.
3) Drive shaft.
A CV drive shaft is another good investment, but there are variables here too. Best option is to change the tail shaft of the transfer case AND the drive shaft at the same time. This is another mod that works with other modifications without having to be redone, unless you change rear axles, that is. Changing the tail shaft accomplishes other things too. It is shorter so that you can install a longer drive shaft and thus decrease the drive shaft angle, and it solves the problem of losing oil from the transfer case if you have to remove the rear drive shaft.
4) Extended height motor mounts
You can install a 1" taller motor mount - available from Currie - to raise the motor. This changes the angle of the motor, transmission, transfer case to the rear axle. It is a very slight angle change, but where just a little bit of angle change is needed, it works well. If you have a body lift, the motor mount lift will also help to get your engine fan and radiator back in line so that the fan does not hit the bottom of the fan shroud.
All these things are fixes for the drive shaft angle problems that develop when you install a lift. Also keep in mind that the angle setup is different for a regular u-joint (stock) drive shaft and a CV drive shaft. U-joint splits the angle of the drive shaft between the u-joints. CV joints take all the angle at the CV end and a maximum of 4 degrees at the u-joint end (pinion end). Lowering the transfer case to take some of the angle out of the rear drive shaft is a commonly done mod, but is probably the least desirable answer to the vibration problem. Why do a lift, then do a lowering job right in the middle of the vehicle where it is the MOST likely to get hung up on high center?
Lots of things to consider. Hope this helps.
Doug '97 TJ
My Web Site
