SOA or Pro Comp Coil Conversion - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-19-1999, 06:46 PM
I am either going SOA or the Pro Comp Coils on my 94YJ. (The present 3" susp is not quite enough) The Jeep is a daily driver (20K/yr) but I wheel it in the rocks almost every other weekend when trails are open.
Any suggestions would be appreciated.
post #2 of (permalink) Old 12-20-1999, 01:35 AM
Re: SOA or Pro Comp Coil Conversion
If you want more than 3" then SOA would be a better choice...however, you would be better off using your original springs...the SOA will give you about 5"...If you already have 3" and use those springs then you end up with about 8"....and a rough ride. There is some good information in some of the old posts regarding SOA's. Some of the factors to consider are the need for anti spring wrap bars, CV drive shaft...etc. If money is not a consderation then maybe you want to go with the Coil Over conversion. I guess I have now added to the confusion....Good Luck.
John......southern CA
84CJ7,3"lift,32"BFG,4.11's,ARB,Solid Axle's
post #3 of (permalink) Old 12-20-1999, 12:39 PM
There is a good article on the Pro Comp coil conversion at
www.4x4wire.com
Check it out!
Rockdog
post #4 of (permalink) Old 12-20-1999, 02:01 PM
The coils are sweet but I would go SOA....just personal opinion.
absolutjeep
http://members.tripod.com/iluvjeeps
post #5 of (permalink) Old 12-21-1999, 08:37 AM
For a daily driver if you can pony up the bucks, the coil conversion is your best choice. The SOA is a great way to get the flex and clearance you want at a resonable price, but the road manners leave alot to be desired. If you choose to go spring over stock springs are your best choice. There are alot of great write up on this on the web.
AustnJPR
http://www.geocities.com/austnjpr/
post #6 of (permalink) Old 12-21-1999, 11:20 AM
Thanks to all, I'm still not positive but I'm leaning to the coil conversion since I do spend so much time on the road.
post #7 of (permalink) Old 12-21-1999, 04:04 PM
>The SOA is a great way to get the flex and clearance you want at a resonable >price, but the road manners leave alot to be desired.
I've driven a couple that were setup properly and the road manners were just as good as stock. Th problem is that most people either don't know how to set them up properly, or they don't want to put in the money & time to do it right.
Jeepskate is offline
post #8 of (permalink) Old 12-24-1999, 07:25 AM
I have been running a SOA with OME's for about a year now, everyday. No track bars, just a sway bar. rancho 9000 up front and 5000 in back. Awesome on the trail and great on the street!
I won't change a thing
Rob
Yellow87YJ
