Doing the clutch - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-14-2000, 06:49 PM Thread Starter
Doing the clutch
Okay, I have to change my clutch and bellhousing. I was checking out how to do it in books and looking underneath. Here's how I see it. It's a T-5 attached to a 258
Rent tranny jack. I have a floor jack for the engine and jack stands for the axle.
Undo speedo cable, vent line and reverse thing and clutch linkage
Here's my first question- do I undo the driveshafts before taking off the crossmember? I'm a little unsure of how to get the driveshafts apart, so if someone could help.
Put jack under engine, undo tranny mount, remove crossmember
unbolt tranny from bellhousing?
slide tranny back and out of way.
Unbolt bellhousing
Remove throwout bearing
Unbolt clutch cover in crisscross pattern
Remove cover and clutch plate.
Unbolt flywheel in same pattern-have flywheel resurfaced
Change wick in pilot bushing
Okay- anything I missed or should know about so far?
On reinstallation I know to use the clutch alignment tool and pretty much reverse order of removal. I know that to get the tranny remounted I might need to move the jack under the oil pan a tad.
While everything is out, is there a way to eyeball the rear main to see if that should be done?
I'm pretty nervous about this cause it's my first time doing anything major myself.
Hope you all can help guide me.
If anyone knows of webpages that might help, please let me know
thanks a bunch
Sean
Reitman is offline
post #2 of (permalink) Old 06-14-2000, 07:06 PM
Re: Doing the clutch
Did my first clutch last December; not that bad of a job. My CJ had T4 and 258.
Definately remove driveshafts and get them out of the way. Mine were held to the yoke with straps (as opposed to u-bolts), used a 1/4" 12 point socket to take out the little bolts. If memory serves they were actually external torx bolts, but the 1/4 12 point worked fine.
Don't think you have to unbolt the bellhousing. I swapped in a T-18, so had everything out and apart.
Lots of socket extensions and universal 9/16" and 1/2" sockets will come in handy. It's helpful to have another set of hands under there when you're putting it back together. One person to put in bolts and one to benchpress tranny and T.C.
Replace the throwout bearing. They are cheap, and it's way to much work to do it again just for the bearing.
Lowering the transmission slightly made it easier to get to the top bolts in the bellhousing. I actually dropped it all the way down (just the motor mounts holding everything) to get to the last two bolts.
Good luck,
Max
82 CJ7, 258, T-18, 4" BDS, York air, Warn 9500Hsi
CJ money pit is offline
post #3 of (permalink) Old 06-14-2000, 07:57 PM
elusive's Avatar
just a hint to make it go easy.. get (3) 10" extensions and take the bolts holding the bellhousing on out fom BEHIND THE TRANSFER CASE.. if you stick your head up there, and look towards the engine.. you'll be able to see almost all the bolts.. dropping the skipplate does work well to get at those last 2 bolts....
~~Elusive~~
it's sort of still a cj thingy....see it at http://www.jeepgod.net
elusive is offline
post #4 of (permalink) Old 06-14-2000, 08:19 PM
Don't mean to sound cynical...but why not get your hands on a Haynes manual and follow step by step?
[img]/wwwthreads_images/icons/cool.gif[/img]
JK
O|||O
78CJ5 360
jeepsternaut is offline
post #5 of (permalink) Old 06-14-2000, 08:22 PM
Too bad you don't have the Iron Duke.....It was actually easier for me to pull the engine to do the clutch (probably the only advantage of that little wimpy motor)
Bob N
"Think your new truck is better, let's go wheeling and see"
post #6 of (permalink) Old 06-14-2000, 08:36 PM Thread Starter
I've got the manual and the Jeep bible, but everyone who has done this before might have a better way to do things and might know little tricks to make it easier. I'm just trying to supplement the books with some real life know how.
Sean
Reitman is offline
post #7 of (permalink) Old 06-15-2000, 02:05 AM
yes deffinatly use that clutch tool.i tried to eyeball it .needless to say it didnt work not to mention i tried to do it all myself.you do need an extra set of hands for sure.i dont know how easy you try to make a job,but make sure you keep all the bolts in a bowl or something i had to make two trips to the hardware store .im kinda sloppy when i work on my jeep.good luck
