Drivetrains - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-12-2000, 08:04 PM
Drivetrains
Anyone have any input about a 350 Chevy engine, a 350 Turbohydramatic, and a NP 205 transfer case for a 1974 CJ5? I have accumulated most of the components and have heard from some that I am crazy to replace my original components. I am open to any input from anyone that has any advice to give. Thanks
post #2 of (permalink) Old 06-12-2000, 08:40 PM
Re: Drivetrains
I would go right ahead if I were you I had a chevy blazer with the equipment you listed I put 225,000 on it befor the speedometer broke after which point I drove it for about 2 more years putting it up to about 275,000 and then I sold it to a guy who is still using it
post #3 of (permalink) Old 06-12-2000, 09:31 PM
Re: Drivetrains
length? what are you planning to use for a rear drive shaft?
your stock drive shaft is about 18" collapsed. the turbo 350 is 6" longer than the 3speed manual, the 205 is how much longer than the stock dana 20? I really don't think you will have the room to do it.
the tubo 350 with a dana 20 will work, but you might need to eliminate the fan and move the engine forward, as close to the radiator as possible.
good luck, jjc
post #4 of (permalink) Old 06-13-2000, 02:02 PM
Re: Drivetrains
350, 350, and 205 is a very strong combination, currently running same in a 74 K20 4x4. However, I agree with jjc as it is a pretty long combination. Measure first.
post #5 of (permalink) Old 06-13-2000, 02:50 PM
Re: Drivetrains
I agree with the above posts, LENGTH is you biggest problem. Jeep never put an auto in the early CJ5's because the were way too long. You MIGHT get by using you dana 20 mated to the TH350 and moving that SB350 all the way forward. Chances are you will end up with around 11" drive shaft that way. If you are dead set on using that V8 find a 4 speed. A SB 350 sm435 and a NP205 could fit also. How about a 4.3L V6 mated to the TH350 and NP205. The 4.3L is a good engine from what I've heard/read. I run a SB 350, T-18 4speed and a scout Dana 300 (same length as dana 20) in my CJ3B (~80" wheel base) and my drive shaft is 15.5". I'd hate to get much shorter!
My name is Ted, and I'm a Jeep-a-holic. [img]/wwwthreads_images/icons/laugh.gif[/img]
[email protected]
post #6 of (permalink) Old 06-13-2000, 08:26 PM
Re: Drivetrains
Checkout the July issue of 4WHEEL Drive and suv mag. They did a write up on a 304/904 automatic/dana 20 in a CJ5. They had to move the motor forward 2" and redrill the rear axle perches to move the rear bach 3/4". This gave them a 13.5" rear cv driveline.
C-Ya.....................kh
Junkfood is offline
post #7 of (permalink) Old 06-14-2000, 01:23 PM
I Do This For The Glory
JEEPN's Avatar
Re: Drivetrains
I have the SM465 and NP205 in my Scrambler, and I can it'd be a little long for a CJ-5. The adapter between the two is quite long, and it's 3.5" longer than the stock SR-4/D300 setup.
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7"Lift/33"TSL's/IHC D44's 4.10's Lock'd
JEEPN is offline
