2 questions-steering and trans. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-11-2000, 04:28 PM
Okay Jeep guru's help me out here:
1) What tilt steering columns will bolt into a Jeep, are there any other cars that line up without modification into an 86 CJ-7 manual?
2) What are the best choices of manual or automatic transmission to run behind a chevy 350 and in front of a Dana 300?
Thank you,
Dave
post #2 of (permalink) Old 06-11-2000, 04:36 PM
Re: 2 questions-steering and trans.
No DIRECT bolt in columns im aware of, some say there are, other say there arent.
you can buy a new one for a hair over $200
find a used Cj one for about $100
or, if you can measure/cut/weld you can fit any column from a GM car into a CJ.
some guys have been using late 60s/early 70s Caddy columns for the tilt/telescoping feature.
all or most of the electrical connectors will be the same on the modern GM columns ( Jeep actually used a GM column), but the length and spline count can vary.
its as simple as shortening the shaft between the steering box and the end of the column usually.
OzarkJeep
77 CJ5, in a bunch of sanded and primered pieces
ozarkjeep is offline
post #3 of (permalink) Old 06-11-2000, 07:46 PM
elusive's Avatar
1) from everything i've seen, early 80's chevy vans have steering columns that go into cj's easily, and they are all tilt
2) now this is a little harder... manual or auto?
a)manual choices..sm 465 pro.. bolts to engine, easy to find
con..doesn't bolt to dana 300, no O/D
t-18...well it won't bolt to any of this stuff lots of adapters and $$$,no O/D
nv 4500,, lots of $$$..then lots more for adapters. but it is THE best tranny out there..
auto choices..\
th400..easy to find, adapter is $579 to a dana 300, kinda long..making poor driveshaft angles
th350..same as above, doesn't eat as much power, not as strong
th 700r4..same, but REALLY not as strong..does have O/D though
tf 727.. well it would be pretty odd to bolt it to a chevy engine, but it does bolt to a dana 300..
your best bet?? depends on you.. if you have the $$$ get the nv 4500
if not, I'd go sm 465 with an np 205 x-fer case.. i have that in one of my jeeps and the granny low makes up for the not as low/ low range..
sorry i couldn't help, I probably made the decision harder for you...
~~Elusive~~
it's sort of still a cj thingy....see it at http://www.jeepgod.net
elusive is offline
