York problems... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-09-2000, 06:46 PM
York problems...
Well, after I got the t-18 in, I started working on the York. It has one big problem, though. It leaks oil like a pig when it is pumping. It's mounted on its side, and the suction line is on the high end. Any idears on how to slow/stop the oil? I have an oil/water separator on my air line, and it fills up in about 1 minute of pumping...The resorvoir on the separator is about the size of a small juice glass. Why is the york leaking??? Dave? OZ? ANYONE!!!
Thought in middle of modifications: "Maybe AMC did it right the first time...Naah."
post #2 of (permalink) Old 06-09-2000, 07:08 PM
Re: York problems...
How much oil do you have in it?
I dont know what the NORMAL amount of oil from a sideways mounted YORK is. maybe someone else can enlighten us.
if its an internal flaw in the compressor it self, ill swap it out with you.
OzarkJeep
77 CJ5, in a bunch of sanded and primered pieces
ozarkjeep is offline
post #3 of (permalink) Old 06-09-2000, 08:16 PM
[img]/wwwthreads_images/icons/tongue.gif[/img] It could be too full of oil. The oil level can be way less than half way and work just fine. Also....there is a slight possibility that the crankcase vent may be plugged up....slight, but possible. The crankcase vents into the intake cavity, under the head. You can check this by removing the side plug that is now on top, and checking to see if it is grossly under pressure. If it is, you can run a vent line from your top plug to the compressor intake air cleaner. We always used 10W oil, and got a zillion hours on these units on our service trucks and well rigs. [img]/wwwthreads_images/icons/tongue.gif[/img]
CJDave
Quadra-Trac modified by the crack moonguy[img]/wwwthreads_images/icons/wink.gif[/img][img]/wwwthreads_images/icons/smile.gif[/img][img]/wwwthreads_images/icons/tongue.gif[/img] transfer case team.
CJDave is offline
post #4 of (permalink) Old 06-09-2000, 09:31 PM
z50k2's Avatar
I have the same problem. I figure it will eventually get to a decent level and stay there. I put in a coalescing (sp) filter in line and run the drain hose to the intake. I have a petcock at the bottom and open it when the pressure is less than 10 psi. That recycles the oil back into the system. I also have an unloader valve in my switch that allows the compressor to cycle on without a load. That exhaust on the switch does get real messy once and a while, but I soap it off and forget about it until it gets ugly again.If you ever find out the correct amount of oil on the sidemount installation, please let us know...seeya...
CJ-7,401,T-18,Detroits,etc..
http://hometown.aol.com/ericselz/myh...e/profile.html
z50k2 is offline
post #5 of (permalink) Old 06-09-2000, 09:59 PM
I'm not 100% sure, but on the older Fords that had the big cast Rotolock compressor, which were mounted horizontal, they called 1 inch. On some other aftermarket a/c systems that I used to install, which were mounted vertical, (Yorks) the spec was no more that 11/8 inches. This was measured from the crankcase fill hole with a dipstick made from a coat hanger.
They called for 525 viscosity refigeration oil. I don't remember any specs that were out of the ranges from 7/8 inch to 11/4 inches. By the way, 525 viscosity refigeration oil is the same as "vacuum pump" oil, but has been dehydrated. Vacuum pump oil is about 1/4 the price.
dorfs is offline
post #6 of (permalink) Old 06-10-2000, 08:37 AM
[img]/wwwthreads_images/icons/tongue.gif[/img] You can get vacuum pump oil at your local "Dairy Supply"....MOO![img]/wwwthreads_images/icons/crazy.gif[/img]
CJDave
CJDave is offline
post #7 of (permalink) Old 06-10-2000, 12:10 PM
I don't know why but for some reason 4 ounces comes to mind. I think that is the amount of oil the york needs to stay lubed up.
Axlesupagain[img]/wwwthreads_images/icons/crazy.gif[/img]
http://home1.gte.net/lrgreen2/index.htm
