AMC 360 Burning oil, but where? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-04-2012, 04:17 PM Thread Starter
So I'm spooling up to get back to work on my CJ project. I fired up the donor 360 today to move the donor CJ closer to the garage for removal of some parts.
The PO mentioned that it burns oil. At first, it showed slight oil burning (very faint blue smoke, barely visible. At operating temp, the blue smoke increased a lot.
It runs and sounds great. As I understand it, the two most likely sources of oil are bad rings and bad valve seals.
If the engine burns more oil at operating temp than when cool, would that point to the valve seals more so than rings? I have a second 360 that would desperately need a rebuild (won't spin by hand). Could I rebuild those heads with new valve seals and swap them on the running motor?
Jeep...need I say more?
ExtinctJeep is offline
post #2 of (permalink) Old 03-04-2012, 11:04 PM
I understand your reasoning however Iím not sure you can guess based on the symptoms. The age of your 360 may have something to do with everything too as during the 1970s some vehicles ran on leaded gas and others required unleaded gas. The deciding factor on having to use cats and unleaded was based on the GVW of the vehicle, a compromised to appease business who complained about having to use a more costly unleaded gas. The GVW limits allowed pickup trucks to be exempt; I donít remember the exact number but it was fairly low. The net effect was that cars now needed to have cats and run unleaded fuel while pickup trucks and other heavier vehicles such as the (FSJ) Cherokee and Wagoner escaped the clutches of the new requirements; at first anyway. Within a year or two the GVW was raised again to catch Ĺ ton and low GVW ĺ ton pickups then finally unleaded became the law of the land for all. The CJ unfortunately was considered a ľ ton truck out of the gate and was saddled with a cat by 1973. (maybe 1972) The purpose of this bit of history is that as long as an engine ran leaded gas the valve stem seats did not need to be hardened as the lead in the gas provided engine component lubrication that unleaded gas of course doesnít have so depending upon the age of your 360 it may or may not have hardened seats which may have a bearing on where/how the oil is getting into the cylinder to be burned. The other the factor is expansion. If seats, or rings for that matter, are warn and expand when heated up the oil could be coming from either seats or cylinders or both.
1978 CJ5, AMC 401, CJ T18, Scout D300, 2 1/2" Lift, Locked Front/Back
Saddle Tramp is offline
post #3 of (permalink) Old 03-05-2012, 05:22 AM
Extinct was asking abut seals, not seats. The problem with the valve seats is that unleaded gas can, in theory, cause rapid wear of non-hardened valve seats, allowing combustion gas to leak past the valve. Unleaded gasoline doesn't cause any problem for valve seals, as far as I have ever heard, so is unrelated to oil leaking down the valve stems and being burned.
Were I doing this project, I would run a dry & wet compression test. That will definitively quantify the condition of the compression rings, and that will pretty accurately tell you the condition of the oil control rings. If dry compression is close to wet compression, the rings are in good condition and your oil burning is coming from somewhere else, and not necessarily valve seals. A bad PCV valve can suck oil from the top of the engine into the intake manifold, for example. With a full complement of emission controls there are probably other possible causes. You should eliminate all other possibilities before opening up the engine.
B. Dash Fabrication
Jim_Lou is offline
post #4 of (permalink) Old 03-05-2012, 08:10 AM
Official Curmudgeon
CJ7Taz's Avatar
Quote:
Originally Posted by ExtinctJeep View Post
So I'm spooling up to get back to work on my CJ project. I fired up the donor 360 today ...
So, how long has it been since the donor 360 has been run? If itís been a while, itís pretty normal for it to burn oil. The rings, especially the oil wiper rings get stuck in the grooves due to the oil, mixed with sludge, thickening up.
Higher mileage engines get tapered cylinder walls, flaring toward the bottom, and out of round bores from wear. If the rings arenít free to follow the distortion, they can allow oil to get into the combustion chamber. Run it for several hours before you do anything drastic.
If it turns out to be valve stem seal problems, the seals can be changed without removing the heads. A piece of SOFT rope is fed into the cylinder through the spark plug hole (Make sure there is enough left to pull it out later). Run the piston up by hand until it holds the valves in place. Now, the valve springs can be removed, the seals replaced and the springs and keepers replaced.
CJ7Taz is offline
post #5 of (permalink) Old 03-05-2012, 10:09 AM
Caver Dave's Avatar
I think this is NOT correct... IOW, oil smoke on startup is usually attributed to valve stem seals as it leaks down into the chambers while off & is usually burned off shortly after startup.
Where as worn rings/bores (as Taz mentioned) usually bring on the constant oil smoke... as the oil warms up, it flows better and more easily pushed past the rings into the chambers.
Quote:
While I'm unsure if they ever changed their methods on "hardening" valve seats... I was told they were "induction hardened" by electric element just around the seat area, rather than hardened seats being pressed in, typical in most Chevy/Ford(?) heads.
I have seen these seats first hand when the "sheetmetal" intake gasket got crinkled slightly on #2 cyl (supposed pro rebuild), creating a vacuum leak/leaning on that cyl... completely burning the exhaust side seat area away to the point of NO compression
A used & recently rebuilt set of heads from a local bud was cheaper than having mine repaired...
Ditto, but add a leakdown test after dry/wet tests
Quote:
Ditto, if it's been sitting for months expect some smoke initially, but after 15-20 should be gone. If the rings *ARE* stuck, the backyardigan method is ATF or MarvelMO dribbled into the cylinders and left to work for a few days. it can even be added to the crankcase to de-sludge the block, but be sure to not run it too long and expect to replace all the now weeping seals
Caver Dave
'72 "Mossy Edition" Commando
the Trail Forge
Caver Dave is offline
post #6 of (permalink) Old 03-05-2012, 12:31 PM
Official Curmudgeon
CJ7Taz's Avatar
I forgot to mention, CHANGE THE OIL.
CJ7Taz is offline
post #7 of (permalink) Old 03-06-2012, 10:37 AM
Caver Dave's Avatar
Definitely, as "some" products (STP/Motor Honey/Restore) have additives that make the oil "cling" better and WILL cause smoking from an otherwise healthy engine!
Caver Dave
the Trail Forge
post #8 of (permalink) Old 03-17-2012, 07:30 PM Thread Starter
Thanks folks. I'm planning to pull the engine over the next month and move it into it's permanent home (my other CJ). I'll do some of these tests after it is in the new frame.
