Axel shaft end play. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-08-2000, 04:25 PM
Are the axel shafts on a 35c supposed to move in and out of the tube. I have about a 1/8 to 1/4 inch of play. could this be bad axel bearings..
This is on my non c clip 89 wrangler. Thanks
Dirtybird
89 YJ 4.2, AX15, Procomp 4" Lift, MSD6a, and just gerttin started......
post #2 of (permalink) Old 06-08-2000, 04:50 PM
elusive's Avatar
Re: Axel shaft end play.
i doubt it.. you would know if the bearing were bad! 1/8 is fine... a bit much, but nothing to run and fix
~~Elusive~~
it's sort of still a cj thingy....see it at http://www.jeepgod.net
elusive is offline
post #3 of (permalink) Old 06-08-2000, 06:16 PM
a small amount of play is fine. just be sure to inspect the retaining plate once in a while to make sure it has not deformed.
dan
<font color=blue>Good things come to those who do research!!</font color=blue>
post #4 of (permalink) Old 06-08-2000, 11:59 PM
As long as you don't have any problems with gear oil/grease leakage, you should be in good shape. This could be a sign of bearing wear, but you will be able to hear the bearings as you spin the axle if it gets too bad. The play could also be the sign of a warped retaining plate. If you do decide to take the axleshaft out, a good trick is to only jack up the end you are working on so the axle dope won't spill out.
post #5 of (permalink) Old 06-09-2000, 12:04 AM
Chris Allmond...89YJ/33"/2-3"lift: engine\tranny\rearend swap in future
