Power Steering info! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-08-2000, 09:33 AM Thread Starter
Can anyone tell me what vehicles power steering can be salvaged from to install into a 1984 cj. A jeeping aquaintance without access to the internet would like to install power steering in his daughters jeep. He is also looking for a hardtop for same vehicle.
thanks
Enjoying Montana's Big Sky (& rocks & rivers & mountians etc, You get the picture.)
jfralph is offline
post #2 of (permalink) Old 06-08-2000, 04:32 PM
jeepgod's Avatar
Re: Power Steering info!
well the gear box.. any jeep.. wagoneer.. j-truck.. yj, tj, and most chevy's have the same box.. for the pump.. mmm.. probably needs one off a 258 6 cyl.. if that is what he has.. and get the brackets with it.. probably could use something off a amc 232.. its the same block.. but might need the brackets for the 258 jeep... i have the brackets.. and would part with them.. since i no longer own a 258..
survival is instinct, but living takes guts
http://www.jeepgod.net
jeepgod is offline
post #3 of (permalink) Old 06-08-2000, 04:47 PM
any Vbelt drive saginaw pump ( Gm)
youll need the proper brackets for an AMC 258 tho, check out some AMC cars.
the gear boxes arent all the same, some have different splines to the steering shaft, others have completely different steering ratios, I dont know which are good/Bad, only that they differ. Most Jeeps seem to have really quick turning ratio.
Id suggest a CJ gear, anyother pump/258 brackets to be safe.
OzarkJeep
77 CJ5, in a bunch of sanded and primered pieces
ozarkjeep is offline
post #4 of (permalink) Old 06-08-2000, 05:05 PM
jeepgod's Avatar
yes forgot about that.. i am using a wagoneer gear box.. and i had to use the end of the shaft for it.. and just slide into the upper shaft.. sorry about that..
jeepgod is offline
post #5 of (permalink) Old 06-08-2000, 06:04 PM
When I put power steering into my CJ I used the box and pump from a 79 Wagoneer. The spline count and diameter on the input was the same as my old manual box unlike the CJ boxes which have a larger diameter. It's an easy fix though. You just change out the bell coupler on the bottom of the shaft. While it's true that any V-belt Saginaw pump will work, the pulley may not have the right offset to line up with the other pulleys. I used the pump brackets and pulley from an Eagle wagon with the 258. My box is pretty fast as it is a variable ratio.
post #6 of (permalink) Old 06-09-2000, 11:17 AM Thread Starter
Thanks, Lots of AMC's and old waggoneers at the junk yards.
jfralph is offline
