building a gas tank?! - Page 2 - Off-Road Forums & Discussion Groups
post #11 of (permalink) Old 07-15-2009, 05:58 AM Thread Starter
jeepjunky's Avatar
dont you mean a rust skid plate...the Heep has no steel on it...just rust
jeepjunky is offline
post #12 of (permalink) Old 07-15-2009, 09:07 AM
Quote:
First off, you don't 'NEED' baffles in a jeep fuel tank.
Not to be disagreeable, but then I usually am... I will.
Some Jeep tanks (like a poly) have a "well" molded into the tank. It's in this place the siphon is going to sit. The well keeps a little gas in the siphon area at all times.
Which brings us to the "Don't Need" a baffel. In most cases you don't... but what happens you're off camber and need the fuel that's flowing to one side of the tank? Well, the engine sputters, and dies. Hopefully you don't sputter and die.
It's even more important for fuel injected vehicles.
post #13 of (permalink) Old 07-15-2009, 01:10 PM
Aaron871's Avatar
Auto Performance Engineering - Walbro fuel pick-ups
We burn Eprom Chips for throttle body conversions (Email [email protected])
Access our free TBI Conversion Information
C.J.O. Buck Wild Racing
O.G. 'Wreckin Crew'
Degenerate Wheeler
Aaron871 is offline
post #14 of (permalink) Old 07-15-2009, 02:22 PM
TeamRush's Avatar
[QUOTE=LEVE;1547429]Not to be disagreeable, but then I usually am... I will.
Some Jeep tanks (like a poly) have a "well" molded into the tank. It's in this place the siphon is going to sit. The well keeps a little gas in the siphon area at all times.[quote]
Until this week, I would have agreed with you...
But I've done 3 fuel tanks in the past week, and I have another one going in tomorow or the next day when the proper hardware gets here...
This is the 15 gallon tank for a '76 to '86 CJ,
And as you can plainly see, there is a RAISED PAD, rather than a depression (Well or Sump) for the fuel tank.
Both the fuel filter 'Sock' and the fuel gauge float rest on this raised pad when the fuel sender/siphon is installed properly...
This is the same tank rotated vertically to keep sender and raised area on the same ends...
This makes NO SENSE to me at all since it makes the last 1/8 tank completely inaccessible to the pickup and should in theory make the gauge read incorrectly...
As for the 'Polly' Tanks...
They DO have a slight sump in the middle, right where the filter sock/suction tube and gauge float will land in them.
Look for the wet spot, the 'Sump' is less than an inch depression in the bottom of the tank, and all located to the rear of the tank (Top of this picture)
And again, this is the same tank rotated vertically so it shows the sending unit on the same side as the picture above...
So Many Cats, So Few Recipes...
TeamRush is offline
post #15 of (permalink) Old 07-15-2009, 09:03 PM
Official Curmudgeon
CJ7Taz's Avatar
I don’t know man. That metal tank doesn’t look like it has a bottom, just 2 tops put together.
CJ7Taz is offline
post #16 of (permalink) Old 07-15-2009, 10:01 PM Thread Starter
jeepjunky's Avatar
found a cheep poly 20gal today and installed it with some modifications. What I did find it that the fill and vent bungs on the stock tank were 3/4" and 1." On the poly tank they are 1" and 1 1/4." The only way I found to fix this was use the 1" on the 1" and found a copper reducer at the home store (3.99 that was 1.25-.75" seems to have worked, especilly sence the other options I was finding reqired fab, weld and $20+.
