Steering setup, inverted Y vs Inverted T? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-14-2009, 10:58 PM Thread Starter
Neurosis's Avatar
About four years ago I bought a Currie steering setup for my jeep. I loved it in the beginning but as I started to go through TRE's I am starting to change my mind about this setup. Especially now that the Drag Link TRE is shot. I cant just replace the TRE, I have to replace the whole drag link to the tune of $200. Plus the TRE that attaches to the pitman arm is shot as well and that is another $50.
I found a few places that sell a 1 ton steering setup along with beefy TRE's that only cost about $35 each and the bonus is that "ALL" of the TRE's are replaceable. The setup however, is an inverted T steering setup rather than an Inverted Y. Are there any cons to having an inverted T setup over the Y?
here is a link to the setup I am looking at.
jcr offroad 1 ton steering
97 TJ
Neurosis is offline
post #2 of (permalink) Old 05-14-2009, 11:33 PM
In general I think the Inverted T is better then Y. Y works okay when the Drag link and Tie rod are very close to parallel. If they are not then Toe in changes a lot depending on ride height. Get the inverted T I think you will like it.
My only suggestion would be to shop around $314 sounds a little high to me but I have not looked at these in a few years, Check with Parts Mike There Kit is only $259.
Also you will need a reamer to open up the holes in the Knuckles and pitman arm, these are $40-$60 for the cheap ones. This is also a good time to consider reaming the Knuckles from the top to get the tie rod a little higher. Turn the reamer real slow clean it often and use lots of good cutting oil such as the high sulfur content stuff used to thread pipes.
Wilhelm
bandhmo2 is offline
post #3 of (permalink) Old 05-15-2009, 12:30 AM Thread Starter
Neurosis's Avatar
I have been strongly considering doing the OTN setup. Ive read that it requires you to remove some of the spring perch and the sway bar axle mounts. I would really like to go over the knuckle however but am just worried a little about whats involved having never done it or watched anyone else do it. I also worry about my steering geometry and the possibility of having to relocate the axle side of the track bar and my welding skills are not quite something that I trust my life with.
I realized that I have to ream the knuckles and pitman arm. Thats not a big deal. I havent seen them (the reamers) for as cheap as 40 - 60$ though. I need to shop around. As far as the steering kit price goes, Ive priced a DIY and it would cost me close to $200 if i were to make the rods myself (cut, drill, and tap). The TRE's average say $35 * 4, and then you have to buy the tube. I priced the tubing at about 15$ per foot. I may try parts mike. I was going to get their crossover steering set up but someone talked me out of it due to the steering geometry problems.
97 TJ
Neurosis is offline
