Share your thoughts - compare CJ fuel sender to Bronco sender
As any CJ owner knows it's just a matter of time before the fuel gauge stops working. My stock gauge was replaced several times, each time the fix worked for short periods and then quit.
My last repair was to add in an aftermarket fuel gauge (Autometer Sport-Comp gauge). Of course this gauge isn't built to be installed in a Jeep. This causes the needle to waver. It's constantly bobbing back and forth.
At first the gauge would still be in the "ball park" of the existing fuel level. But over time it seems to have lost any REAL information. I can only judge whether there is fuel in the tank by how far UP the gauge the needle goes. This isn't very comforting.
While talking over the LONG list of repairs I'm about to get into. It was mentioned that the Fuel gauge no longer works. And "something should be able to be done" to make it read right.
A quick reference to some of my Bronco aftermarket books, leads me to think that I can modify a (1995ish) Bronco sender to fit onto my Jeep sender's mount and install it into my Jeep tank (20 gal poly).
Of course all this thinking is just running me in circles until I get a Bronco sender in my hands. And this fix will be pretty low on the agenda any ways.
But I was hoping somebody that knew more about the gauges and senders would chime in, either to tell me that I'm on to something. Or that I'm totally clueless. It's about an even gamble at this point.......
Whatta you think? In theory, would installing a Bronco sender into my CJ with an aftermarket gauge work?
I realize I still have some work to do. I'm just curious if there is an obvious (probably electrical) reason this shouldn't work.
Thanks,
Drew
