-   -   5.7 Vortec Wiring harness - Painless or use factory (https://forums.off-road.com/jeep-short-wheelbase/231986-5-7-vortec-wiring-harness-painless-use-factory.html)
dugs_cj3a 04-20-2009 01:50 PM
I recently picked up a 98 5.7 vortec, ecm, and wiring harness and plan to install in my CJ5. I've been doing a little research and I know given enough time I can hack up the factory wiring harness to work. My question for those of you that have done this before, if you had it to do all over again would you have spent the money and purchased a Painless wiring harness?
Thanks
Doug
TeamRush 04-20-2009 02:46 PM
Quote:
Thanks
Doug
What 'Factory Wiring' do you think you have to 'Hack Up'?
All you really need from the factory harness is the 'Ignition' power feed,
the rest for the fuel injection sensors, injectors themselves, ect will NOT be in the factory harness since there is no fuel injection...
And there are SEVERAL COMPANIES that makes Fuel Injection harnesses to run between sensors, components and computer...
The one I like the most is from Arizona Speed & Marine, but there are SEVERAL...
Now, if you mean the factory Jeep wiring is crap and needs replaced,
I'd agree with you on that point,
BUT,
For factory replacment harnesses, I sure wouldn't use Painless when there are so many others out there so much cheaper and just as good or better...
Pete88YJ 04-20-2009 04:29 PM
Wow, just this weekend I did the typical intake manifold gasket on my 98 5.7 Vortec in my Suburban. What an unbelievable PITA! I consider myself a fairly skilled mechanic after 20+ years of screwing around with vehicles, but that job was a real backbreaker. Wires wires and more wires.
Haven't started it yet -- I had to order up a new EGR pipe, as I mangled the fitting trying to get it out of the manifold. :( It just wouldn't come out, and I was hesitant to use heat, as the top of the manifold is plastic. :confused: Ha, maybe i'm not that skilled after all. :blush:
Anyway, I guess all I can add is if you have the motor out, I'd do an intake gasket -- they are notorious for going bad.
Good luck
Pete
JeepDawg 04-20-2009 08:46 PM
I did a SBC swap using an engine out of 93 Chevy P/U....the wiring part was easy....once I figured out what was missing....when they cut it out they chopped the wires at the fuse block and left off the VSS.
The only real issue is if your setup came with or without an auto tranny...if it originally came with a tranny, then unless you are putting that in as well, then you need to go Painless.
If it did not have a tranny or you are using the tranny that came with it (most likely a 4L60E) then I would use the stock harness.
The stock harness goes to everything on the engine and then connects to the computer....there are only about 6 connections (and will be the same for the Painless setup)
Battery feed (fuseable link)
Fuse feed Injectors
Fuse feed for Tranny
Fuse feed for fuel pump
Ignition On
Ignition Crank
Brakes (auto tranny...disconnects the lock up converter)
There are some misc wires related to cruise control and ABS brakes.
Randyzzz 04-20-2009 11:31 PM
3 Attachment(s)
I just did my own harness on a 2004 5.3 Vortec. If you are fairly confident in your skills and have patience, it's easily doable. If money is not a real issue, buy the Painless.
Mine was time consuming because I removed all the wiring that I didn't need or wasn't using, and then rewired the Power Distribution Center and combined it with a new underhood fuse panel for the whole Jeep. I could have done the whole thing in a few hours if i just wanted to make it run...
Here's my new fuse box (PDC)-
https://forums.off-road.com/attachmen...1&d=1240288070
PDC closed- connects to the engine and harness with various Weatherpack connectors for a modular system-
https://forums.off-road.com/attachmen...1&d=1240288061
My modified harness- still have to put connectors on all the wires on the left corner, but they will plug into the PDC when done-
https://forums.off-road.com/attachmen...1&d=1240288034
Booger 04-21-2009 05:57 AM
Wayyy back when in 99 when I installed a 5.0 in my YJ, I bought a street rod harness, still have the original harness. It came with a very good manual. I grafted the harness back into the jeep wiring after I removed all unnecessary wiring from the other engine and jeep, took 2 days but everything works, gauges, idiot lights, check engine, etc. I also sent a copy to in2deep when he did his CJ-7. I would surely look around there are several good harness manufacturers out there, just make sure it has good directions/wiring diagrams.
BOOGER
"Sometimes Insanity and Genius walk the same side of the street"
