clutch master issues - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-20-2009, 01:02 PM Thread Starter
Journeyman
PHX?'s Avatar
New problem! Ok so my clutch master keeps losing pressure and then i bleed it and it works perfect again. Air does come out every time i bleed but i am certain the master itself doesn't have leak as i just replaced it twice last week
1990 YJ 258 l6 3.5 BDS lift
/l , [____],
l---L--[]lllllll[]-
()_) ()_)[email protected]=)_)
PHX? is offline
post #2 of (permalink) Old 04-21-2009, 09:04 PM Thread Starter
Journeyman
PHX?'s Avatar
bump!
/l , [____],
l---L--[]lllllll[]-
PHX? is offline
post #3 of (permalink) Old 04-21-2009, 10:06 PM
That's why I don't like juice clutches.
The cups in the slave cylinder are usually knife edge cups, like a brake cylinder.
There has to be slight residual pressure in the lines to keep them sealed. Try putting a light return spring on the fork, to put a little pressure on the slave's cup.
RRich is offline
post #4 of (permalink) Old 04-21-2009, 11:18 PM
Official Curmudgeon
CJ7Taz's Avatar
I know better than to but I have to ask, how does a spring on the fork keep line pressure on the seal?
CJ7Taz is offline
post #5 of (permalink) Old 04-22-2009, 12:01 AM Thread Starter
Journeyman
PHX?'s Avatar
mmmm internal slave...
unless that changes nothing?
/l , [____],
l---L--[]lllllll[]-
PHX? is offline
post #6 of (permalink) Old 04-22-2009, 01:07 AM
The same way a brake cylinder works. The spring keeps pressure on the cup (against the fluid, and drum brakes have a residual valve to keep slight pressure in the line,) keeping it flared out. As opposed to disc calipers - they use square O rings, they don't need something to keep them expanded.
No residual valve in the clutch, but gravity creates the little bit of residual pressure needed.
The clutch slaves have a weak internal spring - when it fails air gets in, just as the complaint says. The external spring pushes the fork, and thusly the piston, back enough.
Plus without the spring, the fork is still touching the fingers - no problem with that really (except for TO bearing wear,) but the vibration from it helps air get in too.
It's not the best cure, but it works - try it!
The right way - replace the slave - but that's alot of work!
RRich is offline
post #7 of (permalink) Old 04-22-2009, 02:51 AM
Official Curmudgeon
CJ7Taz's Avatar
Quote:
It’ll do that with or without the spring.
The springs pull the shoes back against the stop post at the top. If not for the stop, the two cup seals would touch each other and cover the fluid inlet.
Wouldn’t be if it were an external, the kind with a fork you could put a spring on. I thought it was an internal from his picture.
CJ7Taz is offline
post #8 of (permalink) Old 04-22-2009, 05:25 AM
TAZ, lets look at reality. If it was you that had the problem I would have laughed instead of answering. I would have waited for someone else to put up a 3 page dissertation of definitions.
What picture?
Yes, internal you can't get to it. I was thinking of external.
RRich is offline
post #9 of (permalink) Old 04-22-2009, 09:29 AM
Official Curmudgeon
CJ7Taz's Avatar
You not answering, had it been my problem, would have save me a trip for a spring and hoping that it worked.
You could have just said, “Oops”, but you tried to BS your way out.
I’ve never seen a Jeep with a hydraulic clutch but I have seen them on other vehicles. Owned a ’58 MGA with a hydraulic clutch. Best I remember, that MGA and the couple others I’ve seen had no adjustment. It depended on the cylinder not retracting more than necessary to provide the adjustment. If so on a Jeep, an added spring to retract the cylinder would keep the clutch out of adjustment.
CJ7Taz is offline
post #10 of (permalink) Old 04-22-2009, 10:13 AM Thread Starter
Journeyman
PHX?'s Avatar
So I need a new slave? I just put a new cluth and slave in august..
er I'm so confused now
/l , [____],
l---L--[]lllllll[]-
PHX? is offline
