YJ Replacement Body Panels - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-06-2009, 09:09 AM Thread Starter
Apprentice
Does anyone know where I can order some body panels for the drivers side of my YJ. I can find a universal that fits CJ-7's to Wranglers (at least thats what it says), but they are the full length of the side. I just need basically under where is says jeep. I don't want to pay $250 for the whole side when I don't need it.
jgermann is offline
post #2 of (permalink) Old 02-06-2009, 09:44 AM Thread Starter
Apprentice
I did find something that says the CJ-7 driver side body panel will work...anyone know if it will?
jgermann is offline
post #3 of (permalink) Old 02-06-2009, 09:45 AM
Why not just do a little rust repair rather than whole panel replacement?
post #4 of (permalink) Old 02-06-2009, 09:56 AM Thread Starter
Apprentice
I was jsut going to get the panel because if it works, its only $30. The hole in the side of the jeep is about 6" diameter and its partially up in the JEEP on the side. So I will probably have to cut all of that out too. Plus I'm not good at body work so I was figuring instead of cut around everything, it would be easier to cut straight lines. I will take any suggestions though, I'm always willing to learn something new.
jgermann is offline
post #5 of (permalink) Old 02-06-2009, 10:06 AM
Try the junkyard.
BOOGER
"Sometimes Insanity and Genius walk the same side of the street"
Booger is offline
post #6 of (permalink) Old 02-06-2009, 10:07 AM
It's all pretty flat material, and easily worked. My concern is that if you start poking around, you'll find more rust. But heck, give it a try... what do you have to loose (except the word: Jeep)? Moses Ludel's book, the Jeep Rebuilders Bible does a good job of detailing rust repair.
post #7 of (permalink) Old 02-06-2009, 05:52 PM
Official Historian
WILL's Avatar
The CJ7 and YJ pieces are the same because the only difference is how the tailgate mounts and the location of 2 body mounts underneath.
I doubt any repair panel will have the JEEP or JOOP stamped in them. If yours are gone, either get one from another tub or do without them.
WILL is offline
post #8 of (permalink) Old 02-09-2009, 07:25 AM Thread Starter
Apprentice
Ok, I am going to at least try to cut out the rust and repair, if it look terrible I will just order the side panel and get some help installing it. Any know if sheet metal for HVAC duct will work fine or do I need to pick up some metal from somewhere else. I can get the duct metal for free so I figured if that would work, I would try it. What gauge metal would be best?
jgermann is offline
post #9 of (permalink) Old 02-09-2009, 09:32 AM
Match the guage. IIRC, OEM Jeep panels were 18ga. I wouldn't use HVAC material. HVAC duct metal is a very mild steel, and has a coating that doesn't lend well to welding. I'd be trotting down to my local wrecking yard or Pick'N Pull place and getting a peice of trunk lid, hood, etc from a wreck. You'll end up with better metal, just watch the gauge.
post #10 of (permalink) Old 02-09-2009, 09:35 AM
CJs are 16 and 18 gauge - 16 in the floor and the reinforcements, and 18 everywhere else, I think. Duct sheet is thinner than that - probably 22 - besides which it's galvanized, which complicates the welding. I suppose it would be OK to spot weld it but for any other technique you should grind or acid-etch the coating off first. The amount of 18 cold-rolled sheet you need shouldn't cost much, so I'd recommend not using the HVAC stuff.
B. Dash Fabrication
Jim_Lou is offline
