51 Whilly - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-18-2008, 02:39 PM
archie_scout
51 Whilly
Does anyone know what the gap on the spark plugs would be for my 51 whilly
post #2 of (permalink) Old 06-18-2008, 02:49 PM
Try:
.020"
post #3 of (permalink) Old 06-18-2008, 03:57 PM
Overhead-valve engines of that era typically ran a larger gap, like .030" or .032". I guess those flatheads were different. Do you know whether the ignition system weaker, or was it something inherent in the combustion chamber shape that dictated the smaller gap?
B. Dash Fabrication
Jim_Lou is offline
post #4 of (permalink) Old 06-18-2008, 08:57 PM
SilentBob2's Avatar
Jim I think you are really close. I believe that's what mine are at, does
6-12V make a difference ?
SilentBob2 is offline
post #5 of (permalink) Old 06-18-2008, 09:53 PM
Primary voltage shouldn't affect the gap - a 6-volt coil will have double the step-up ratio of a 12-volt coil, so the maximum secondary voltage should be about the same.
B. Dash Fabrication
Jim_Lou is offline
post #6 of (permalink) Old 06-18-2008, 10:59 PM
What was I thinking? Yep, I read the post wrong, and I was thinking Point's gap....
Plug gap is:
Quote:
b. Adjustment. To adjust the gap, bend the side electrode only, and gage the plug with a round thickness gage to a gap of 0.030 inch.
post #7 of (permalink) Old 06-20-2008, 09:41 PM
Official Historian
WILL's Avatar
Quote:
If a 6 volt system doesn't use a resistor in the primary ignition circuit, then it will be about equal to a 12 volt system with a resistor.
WILL is offline
