Ignition, Help Please! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-30-2008, 11:31 PM Thread Starter
Hey guys, I did a search on this but really need to know where to find this part. I dont know how to post photos on here, so I'll describe it the best I can. Chilton label's the part as a lock rack, The part is located in the steering colum. It is turned by the ignition cylinder and pushes a rod that essentially engages the ignition. It cannot be welded back together, poster LEVE put up a photo of it in a post in 06.
If you can help me I also need to know how to replace it. I can get the broken piece out, but that's only because it's broken. a new one would prob. need to be taken down more.
I was thinking about wireing a pushbutton start, but after reading some threads I'm gonna just try to fix it RIGHT! Ya'll have come through for me b-4 so thanks in advance.
Mike
Jedicazador is offline
post #2 of (permalink) Old 05-01-2008, 07:06 AM
That'a a GM part... and NAPA should have them.
post #3 of (permalink) Old 05-01-2008, 09:17 AM
jeepgod's Avatar
yes napa should have the part and to replace it you need to take the steering wheel off.. get yourself a steering wheel puller, it makes things really easy.. once you pull it off.. then its just taking out some screws and pulling the cap off, then the turn signal switch.. then you will have to unbolt the metal piece that the lower portion of the rod goes into from the steering column.. then the part with the key switch should pull off.. and you can replace the rod then..
Survival is instinct, Living takes guts!
jeepgod is offline
post #4 of (permalink) Old 05-01-2008, 11:28 AM Thread Starter
That easy? I'll take the broken part to Napa today and see what they can come up with. Thanks
post #5 of (permalink) Old 05-01-2008, 12:52 PM
jdoggmoney's Avatar
Fairly easy and yes if you take the broken part to Napa, someone will know what you need. Take your time, I would compare the insides of the steering collumn to a 3D puzzle. Take pictures of the disassembly if you have to, go slow, and put it back together in reverse order one step at a time.
Is this the only hammer you've got?
jdoggmoney is offline
post #6 of (permalink) Old 05-01-2008, 04:04 PM
OlllllllOCJ's Avatar
This link might help:
Tilt Column Fix
Dale
Excellent Bad Example
OlllllllOCJ is offline
post #7 of (permalink) Old 05-01-2008, 06:41 PM Thread Starter
Olllllocj great link thanks!
W ell I went to Napa, carquest, checker, and noone had the dang thing. My friend at Checker called Autozone, god I hate that place. well guess? what they had it! 9.99 so Autozone got mybusiness by default! Oh [email protected],I hope it dosnt break in a week!
Thanks for your help ya'll, I'll let you know how it goes
Mike
post #8 of (permalink) Old 05-01-2008, 09:07 PM Thread Starter
Ok I got the colum striped down to the pivot pins, the link states that I can use a 8/32 bolt through, a 9/16th socket or a equiv. in nuts...well as I started the bolt into the pin it started to move YES! man I'm stoked, then.... snap. what the? no ... the darn bolt broke off inside the pin. Ok I'll back it out. no such luck its just some cheep steel that keeps breaking off or getting smoothed out. I think I'll have to tap it, but I've never done that b4. AAhhhhh! Tomorow I'll continue it, I think sometimes its just best to walk away and take a fresh breath before I break something else.
Thanks all
post #9 of (permalink) Old 05-01-2008, 10:30 PM
First you should have a nut and a couple of washers toward the head of the screw.
I know the pictures are not very good.
After you thread the screw into the pivot pin tighten the nut down on the washers and socket to pull the pin.
Maybe a concept that should be covered in that write up.
The pivot pin should be harder than the broken off screw. Hope that you have a tap.
Dale
post #10 of (permalink) Old 05-02-2008, 12:12 AM Thread Starter
olllllllocj I did just as you described musta been really cheep hardware,the link is great! so are the photos. I couldnt have gotten as far as I have without it Thankyou I have bookmarked the link and will be using it often. My neighbor lent me a tap set he has, so I'll takle that in the morning. I just retired last week so I have plenty of time on my hands. Just wish I had a garage to play in
