idle problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-30-2008, 11:27 AM Thread Starter
idle problem
85 cj7 258 6cyl with stock carburetor dies everytime I let off the gas. Will not idle. Checked for vacuum leaks. What is most likely cause of this problem? I assume it is carburetor related. I am considering an upgrade to the Weber 34 DGEC carburetor. Any comments on this carb.
lefty915 is offline
post #2 of (permalink) Old 04-30-2008, 11:52 AM
Click on the graphic... and commit the information to memory;
IMHO, dump the BBD and go with a DIY fuel injection system.
post #3 of (permalink) Old 04-30-2008, 12:15 PM
Since we don't know where Lefty lives, that may or may not be a good idea because of emission regulations. The BBD can be made to run properly. There have been several links to details of how to do it.
B. Dash Fabrication
Jim_Lou is offline
post #4 of (permalink) Old 04-30-2008, 12:23 PM
And... if lefty would fill out his profile... we'd be able to give better answers to questions.... I'm just say'n...
post #5 of (permalink) Old 04-30-2008, 01:12 PM
Yep. Where have I heard that before?
B. Dash Fabrication
Jim_Lou is offline
post #6 of (permalink) Old 04-30-2008, 01:19 PM
OlllllllOCJ's Avatar
Typical problem is clogged idle tubes, mentioned in the link Leve put up.
Or a different version if you click on "Easy Fix...." from the following page.
Carburetor Links
You will also find "Rebuild Instructions" and some other useful BBD things on that page.
A rebuild kit for the Carter is around $20, add a $5 fuel filter and a couple of hours... The instructions that come with the kit should be all that you need.
Unless you have a Weber, no investment, it's going to cost you both time and money.
Many folks have put a Motorcraft 2100 on Jeep 258's and love it. They are cheap if you can find one and more simple to rebuild than the Carter.
Fuel injection would be great but I'm fine with my stock BBD's on two old Jeeps.
Dale
Excellent Bad Example
OlllllllOCJ is offline
post #7 of (permalink) Old 04-30-2008, 06:59 PM Thread Starter
no idle
Thanks, i'll try cleaning the idle tubes. I now have a profile. I am outside Austin, Tx and last year jeep passed emissions after some work. Coming up again in June. I think vehicles over 27 years old are exempt from some emissions testing. What about putting smaller jets on the 34 DEGC weber to reduce rich mixture. I don't know too much about engines and carbs except what I have taught myself by reading and trial and error.
lefty915 is offline
post #8 of (permalink) Old 05-02-2008, 06:17 PM Thread Starter
idle fixed
It must have been the idle tubes. Poked it with a straight pin and sprayed carb cleaner. It runs the smoothest when the mixture screws are both turned counterclockwise about 6 turns out. Is this too far to turn out, since I read that you should start at about 2 and a half turns out.
lefty915 is offline
post #9 of (permalink) Old 05-02-2008, 06:45 PM
Do you mean it idles best with the screws 6 turns out?
That's not normal. There's probably something still blocked or restricted. If so, a rebuild is in order.
B. Dash Fabrication
Jim_Lou is offline
post #10 of (permalink) Old 05-02-2008, 06:56 PM
Yes six turns from seated is a likely little much... But by now you could have just picked up a BBD rebuild kit and moved on to bigger and better things.
It is not very difficult. You don't want to rebuild the BBD - Then Don't.
Even if the carb is perfect... How's the ignition? Stock?
So many just toss out the Carter and start over when it isn't a big problem. But the thousand miles of vacuum line that comes with it just might be.
Dale
