95 Wrangler Fuel Injection Problem Please Help! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-26-2008, 09:19 PM Thread Starter
I have a 95 Jeep Wrangler Rio Grande 2.5 liter, 4 Cyl.
It has sat for about two years because of other issues.
It will not start, unless you pour fuel down the air breather, and as soon as you stop pouring fuel in it will die?
So we have determine that we that we must have a bad fuel pump and we did the OBD thing and we had codes 12,33,54,55. After we installed the new fuel pump it still won't start?
We did some searches on this board and decided to replace the camshaft position sensor and the crankshaft position sensor.Then we did another code check and we elminated the code 54, but we are still getting a code 33 which is air cond. related. It does not have air cond.?
So now we know that the fuel pump is working but still no electricity coming to the connector at the fuel pump? WHY? WHY? WHY?
Timber!
'70 Jeepster "LONG MAY YOU RUN"
'71 Jeepster partster
"The world is a cruel place, for an honest man!"
Timber is offline
post #2 of (permalink) Old 04-26-2008, 09:23 PM
The problem is from the Fuel Pump Relay back... where's the circuit loosing voltage? I'd try jumpering 12 volts directly to the pump to see if the engine runs.
post #3 of (permalink) Old 04-26-2008, 09:32 PM Thread Starter
You're defintely RIGHT! But I'm losing my mind...trying to figure out where the voltage is being lost?
The fuel pump WORKS! BUT we can't get a electrical current to the fuel pump, at the tank?
I'm so happy you responded, because I have read your post from the past so many times, I know...you know what you're talking about!!!
If you would prefer that I call you??? Please PM me, and I will!!!!
Timber!
Timber is offline
post #4 of (permalink) Old 04-26-2008, 09:41 PM
Take a look at Autozone for a Schemaitc. Look at Figure 29, top right side.
Note the ASD relay energizes the Fuel Pump Relay. That relay passes voltage to the fuel pump. So, make sure that relay is working. You've got spark, so the ASD relay is working. Now check to see if there's output from the Fuel Pump Relay. If there is .... check to make sure the harness is good and that the wire's not broken from the relay down under the Jeep to the Fuel pump.
post #5 of (permalink) Old 04-26-2008, 09:49 PM Thread Starter
OK, I also want to mention the ASD seems to be playing games with us???
It will click twice whenever we turn on the switch, as if it is starting to initiate, then it refuses to complete the circuit???
It(ASD) has a sharp click, then kind of a clunk sound...then nothing else happens???
Timber!
Timber is offline
post #6 of (permalink) Old 04-26-2008, 09:52 PM
If the ASD were not working, then you would not have spark to run the engine while you're pouring fuel down the TBI throat. My guess is the ASD is working.
post #7 of (permalink) Old 04-26-2008, 10:12 PM Thread Starter
LEVE...you're giving me great info, but if the ASD is working properly as you suggest, why is there no electrical current at the connector plug before the tank?
I know maybe I'm overlooking the obviously...BUT??? What is the OBVIOUS???
I just don't know what I'm missing here???
Thank you, kindly!!!
Timber!
Timber is offline
post #8 of (permalink) Old 04-26-2008, 10:16 PM Thread Starter
OH! One more thing I need to know?
I read in the Haynes manual that the TBI, and the MPI fuel pumps look the same, but are not???
Can you shed any light on that?
Timber!
Timber is offline
post #9 of (permalink) Old 04-26-2008, 10:29 PM
The TBI and MPI fuel pumps likely do look the same, but the problem is that they're different output pump pressures. The TBI would run about 13psi, while the MPI would run at about 43psi.
The ASD is engaged by the PCM. If that's working, it passes the voltage to the fuel pump relay. So, we need to know if there is any output voltage from the fuel pump relay. If the fuel pump relay is enabled then you'll have 12 volts on it's output connector pin.
Why isn't that at voltage at the fuel pump? There could be a problem with the wiring, or the fuel pump has lost it's ground. That's a pretty common problem with a Jeep.
post #10 of (permalink) Old 04-26-2008, 10:48 PM Thread Starter
OK LEVE, you're obviously a great guy! And I'm not wanting to dispute anything you're telling me.
But first of all I thought I was dealing with MPI '95 Jeep Wrangler, maybe I'm not??? Maybe it's considered a TBI? Remember I'm not as smart as I look!!! LOL
Maybe the problem is...I do have a bad PCM???
Your thoughts on that?
Timber!
Timber is offline
