Ot Electric Load - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-05-2008, 03:45 PM Thread Starter
Rio_Grande's Avatar
Ot Electric Load
We are getting price quotes for a new shop in the back. The building and the like was easy. The Electric however is not working out so easy.
The engineer I met with from duke energy wants a list of all the equiptment I will be running and the load requirements of each. My biggst problem is alot of it s unknown. I intend to at some pint put a mill, lathe, plasma table along with the welders, hand tools, lights heat and the like that I already have. I was thinking about running double 200 Amp service just to be certian. What concerns me is I currently run on a 100 amp sub pannel. That mens I hae 100 amps availble but share it with the rest of the house. I have never blown a breaker. I think it is mostly because I don't weld and run the drill press, compressor and 5 drills at the same time. I may be welding and the compressor kick on that is the biggest surge I see hapening and even at full load that will only consume 71 amps peak. I am looking for some advice on this. Dad said he shot his high and they did the work and install for free. That would be great, but I don't want to short myself.
Ya only go around once, best to enjoy it the first trip.
Rio_Grande is offline
post #2 of (permalink) Old 03-05-2008, 04:18 PM
JeepDawg's Avatar
Check your PM
AKA DDawg16
D44 Flat top in progress...
Link to my Frame up Restore
JeepDawg is offline
post #3 of (permalink) Old 03-05-2008, 04:42 PM
I have all of that stuff running in my shop on a 200 amp service and have never had a problem. Probably the biggest load I ever had was one day I was running the lathe, a buddy was running the mill, the AC was pumping and the compressor kicked on. No problem.
It's good that they'll do the calculations for you, but watch out. If it turns into a commercial connection, you may have rates or charges based on the maximum service.
When I built the shop I put in wiring one or two sizes larger than code - 20 amp circuits on 10 gauge wire for the wall receptacles, 20 amp circuits on 12 gauge wire for the ceiling fixtures. I did that so that in the future I could run more through them if necessary, and also to avoid the voltage drop that starting loads can cause.
The electrician who helped me wanted to surface-run conduit and pull code-size wire that could be easily replaced if necessary. That probably would have been a good course of action and cheaper, but I didn't want to notch stuff around the conduits, and didn't like the appearance of the conduit.
B. Dash Fabrication
Jim_Lou is offline
post #4 of (permalink) Old 03-05-2008, 06:41 PM
I am with Jim, 200 amp service should get you good to go.
2001 TJ Built, Wrecked, then Built Bigger, then rolled and fixed again, now rolled again. Do you see a pattern!!
KentuckyCrawler is offline
post #5 of (permalink) Old 03-05-2008, 07:07 PM
I could weight in on this but won't because even though I hold a current state certified Master Electricians License and several Degrees in Mechanical and Electricity. I have been told by others in soooo many words I didn't know what I was talking about. I will say this there are many variables to consider before making a final decision.
BOOGER
"Sometimes Insanity and Genius walk the same side of the street"
Booger is offline
