97 TJ removing gas tank. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-03-2008, 01:35 PM Thread Starter
Neurosis's Avatar
Im a little curious if anyone knows of a good writeup on how to do this. Im more worried about how to deal with the pressurized line than anything. Im thinking about putting a kilby gas tank skid in since mine is so mangled that it will probably have to be removed with a sawsall.
Thanks.
97 TJ
Neurosis is offline
post #2 of (permalink) Old 03-03-2008, 02:32 PM
Rio_Grande's Avatar
Nothing to it really. I don't see why you would need to take the lines off. unbolt the old skid remove, install new. bet kilby has a writeup.
Ya only go around once, best to enjoy it the first trip.
Rio_Grande is offline
post #3 of (permalink) Old 03-03-2008, 04:26 PM
MTPockets's Avatar
I removed the gas tank on my 2001 TJ a few years ago. I don't recall having any problems with the pressurized line at all. One thing to watch: When you lower the tank be aware that there are several vacuum lines that attach to a fitting on the top of the tank. You can not see these or reach them until the tank is lowered several inches. However, if you lower the tank too much before disconnecting them, you will either break the hoses or break the fitting on the tank. I ended up snapping the nipple off of the fitting. I repaired it with RTV, but would not have had to if I was careful. Good luck!
Found a link: DailyDrivenTJ-Warn Skid Fuel Tank Skid Plate
Scott
"The devil is red, but his money is green."
MTPockets is offline
post #4 of (permalink) Old 03-03-2008, 04:34 PM
I have the procedure from the FSM... send me an Email so I have your Email address and I'll email you a copy.
post #5 of (permalink) Old 03-03-2008, 06:51 PM Thread Starter
Neurosis's Avatar
Thanks for the info guys. Leve, you have a message. Thank you. Has anyone heard anything about the warn tank skid? I can get it for about $40 cheaper than the kilby
97 TJ
Neurosis is offline
post #6 of (permalink) Old 03-04-2008, 05:53 AM Thread Starter
Neurosis's Avatar
MT: that sites write up explained it beautifully. Thank you. Looks very simple. Ive read the kilby writeup and it doesnt explain how to depressurize the line.
LEVE: thanks for the info!
97 TJ
Neurosis is offline
post #7 of (permalink) Old 03-04-2008, 07:15 AM
Depressurize the line by pressing the schrader valve.
post #8 of (permalink) Old 03-04-2008, 08:51 PM Thread Starter
Neurosis's Avatar
I pressed the schrader valve and my tires went flat. Was that supposed to happen?
97 TJ
Neurosis is offline
post #9 of (permalink) Old 03-04-2008, 08:54 PM
Wow... a new airdown tool comes stock wth a Jeep... who'd a thunk it!
post #10 of (permalink) Old 03-07-2008, 08:55 PM Thread Starter
Neurosis's Avatar
Well, the tank is out. It was a breeze! Between the write up and Leve's info I managed to get the tank out (after a good mud scraping) in about 45 minutes. Tomorrow I have to mount a tool box and then bend the rear cross member back in to place so that I can bolt the new skid on. I would have taken pictures but its embarrassing how bad it looked under there so......
97 TJ
Neurosis is offline
