Dana 44 6 lug to 5 lug conversion part 2 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-26-2008, 07:58 PM Thread Starter
Official Historian
WILL's Avatar
Ok, I put my small bearing spindles on the knuckles, disk brake brackets on the spindle, ford hubs and rotors on the spindle and now the problem is the calipers and pads don't fit. What am I doing wrong? Do I need the wagoneer caliper brackets? Are the chevy brackets the wrong ones?
WILL is offline
post #2 of (permalink) Old 02-26-2008, 08:07 PM
Rio_Grande's Avatar
Don't quote me but I thought you keep the waggie bracket and brakes?
Ya only go around once, best to enjoy it the first trip.
Rio_Grande is offline
post #3 of (permalink) Old 02-26-2008, 08:47 PM
Apprentice
I used the Wagoneer bracket but I think the calipers are the same...Jeep or Chevy.
dugs_cj3a is offline
post #4 of (permalink) Old 02-26-2008, 11:30 PM
jeepgod's Avatar
i used the jeep brackets and calipers..
Survival is instinct, Living takes guts!
jeepgod is offline
post #5 of (permalink) Old 02-27-2008, 07:19 PM
jeeperjohn's Avatar
Does it look like the pad wearing will allow the caliper to move off the mounting pins or hit the caliper bracket? Have pics?
Political Correctness - Because people can't handle the Truth
jeeperjohn is offline
post #6 of (permalink) Old 02-29-2008, 06:18 PM Thread Starter
Official Historian
WILL's Avatar
Ok, I bought a pair of waggy caliper brackets and they are the same as my chevy brackets. What am I missing here? I have small bearing spindles, ford hubs and rotors and the correct calipers and brackets but there is no room for the inner brake pad.
WILL is offline
post #7 of (permalink) Old 02-29-2008, 07:52 PM
pontiac58's Avatar
Chevy and the jeep brackets are the same. Calipers are the same.
The problem is you have the wrong spindles. You have drum brake spindles.
There is a easy fix though. Cut both brackets and weld one on the outside of the other. The calipers will now fit.
How do i know this?????
I had the same thing happen to me and i didnt relize what was wrong until a few years later when i did a job on a drum brake truck.
The spindle got burned up. Put on a new spindle and the shoes were at the very edge of the drum. The shoes normally are inside the drum about a 1/4 or so.
What????
pontiac58 is offline
post #8 of (permalink) Old 02-29-2008, 09:31 PM Thread Starter
Official Historian
WILL's Avatar
Thank you so much. Now that I look at the big bearing and small bearing spindles, I can see exactly where you are talking about. I've got two big bearing spindles and a lathe so I'm going to turn them down and make it work like it is supposed to.
WILL is offline
post #9 of (permalink) Old 02-29-2008, 10:28 PM
jeepgod's Avatar
good info jim.. did not know that.. i thought the brackets were the same.. and i knew the calipers were...
jeepgod is offline
post #10 of (permalink) Old 03-06-2008, 04:43 PM Thread Starter
Official Historian
WILL's Avatar
Ok, update.
I turned 2 large bearing spindles down to small bearing spindles. Hubs and rotors are on and calipers and pads fit perfectly.
Now I need banjo bolts. Where do I find those? The threads in the calipers are 10mm fine thread. I need some bolts about 1-1/4" from the bottom of the head to the end of the threads.
WILL is offline
