Oil Change Front & Rear Diff - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-15-2007, 12:51 PM Thread Starter
Carnellc's Avatar
I have a 86 CJ7 and I'm going to replace my front and rear pumpkin seals and oil and my two questions are,
Is there a preferred oil?
Is there any thing I should be looking for and or preventive maintenance I should be doing while I have the covers off?
Thanks,
Carnell
1986 stock CJ7 rebuilt 4.2L 258 more to come
Carnellc is offline
post #2 of (permalink) Old 12-15-2007, 01:02 PM
newguyJD's Avatar
I don't know about prefered brands, however I did find it easier to fill the diff with fluid by finding a peace of hose that would fit into the fill port and long enough to stand up from underneath the jeep with a funnel in the other end,take the little tapered spout off of the bottle and pour it into the funnel instead of trying to squeeze it out of the bottle under the jeep at a screwed up angle.
JD
newguyJD is offline
post #3 of (permalink) Old 12-15-2007, 01:35 PM
JeepDawg's Avatar
Good thing you are pulling the covers off....it's good to do a visual check...look for pieces of metal....if you do find some....it's not exactly a good thing...most likely both pumpkins will be fine.
I like using the synthetic oil.....you pay a bit more but the friction resistance is a little lower.
One note:...if your AMC20 (rear) is a limited slip, then use the right oil otherwise your friction plates will not work correctly.
AKA DDawg16
D44 Flat top in progress...
Link to my Frame up Restore
JeepDawg is offline
post #4 of (permalink) Old 12-15-2007, 02:25 PM Thread Starter
Carnellc's Avatar
Thanks for the tips. I have my manual with me so I can look up the SN numbers to find out what I have. I'll post my findings.
Carnell
Carnellc is offline
post #5 of (permalink) Old 12-15-2007, 02:56 PM Thread Starter
Carnellc's Avatar
How can I tell if it's a limited slip diff?
Carnellc is offline
post #6 of (permalink) Old 12-15-2007, 03:37 PM
Only sure way to to take the cover off and look. The ID tag under one of the cover bolts should tell you, if you know what code to look for, but that doesn't mean that someone didn't change things some time in the past.
B. Dash Fabrication
Jim_Lou is offline
post #7 of (permalink) Old 12-15-2007, 04:13 PM
Novice
Hamilton LJ's Avatar
You might want to invest in lubelocker reusable gaskets. Never scrape gasket and sealer again.
Hamilton LJ is offline
post #8 of (permalink) Old 12-15-2007, 05:38 PM Thread Starter
Carnellc's Avatar
Have you guys heard of using just RTV instead of a gasket?
Carnell
Carnellc is offline
post #9 of (permalink) Old 12-15-2007, 07:21 PM
Yep. It works well. Permatex makes several grades for different applications. Read the label to make sure it's the right stuff.
B. Dash Fabrication
Jim_Lou is offline
post #10 of (permalink) Old 12-15-2007, 08:06 PM
newguyJD's Avatar
Which one would work best for a leaking tranny case?
JD
newguyJD is offline
