Gearing question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-03-2007, 07:14 PM Thread Starter
Gearing question
What gear ratio is stock on a 93 Wrangler.I have 32" tires and would like to know if I need to regear.I tow a fourwheeler hunting and it seems to pull down in fourth gear.What gear should I run with that size tire?
maxxedout is offline
post #2 of (permalink) Old 12-03-2007, 07:45 PM
Journeyman
towman_tim's Avatar
HINT
Crawl under your rearend and look for the tag is will be on the diff. cover bolts
then post the #'s on here and we will tell ya!!!!!
Tim
Why is it that after you get stuck everyone helps you out then tries to make it though the same spot???
85 CJ-7 /258/Hei/4" lift/33"x12.50 Baja claws/4.10 gears/tera-low/ F-Det, R-Spool / Lots O Goodies
03 TJ 4" lift 33" tires more mods to go !!!!!!!
towman_tim is offline
post #3 of (permalink) Old 12-04-2007, 08:27 AM
MTPockets's Avatar
Quote:
Most 6 cylinders were 3.07 but I think there was a 3.55 option. The four cylinders had 4.11, I believe. It's best to crawl under and check to make sure. I have 32" tires and 3.73 gears and if I went much bigger (like over 33") I would regear. But I have an automatic.
Scott
"The devil is red, but his money is green."
MTPockets is offline
post #4 of (permalink) Old 12-04-2007, 08:33 AM
ecamp55's Avatar
When I went to 33's I regeared to 4.27's. The new gears are great on the trail and gave me back my top end on the highway.
1974 CJ5, D30, D20, D44, T15, 2.5" BDS Lift, 33's, Dual ARB's, 4.27's, Front Cage
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
ecamp55 is offline
