YJ Frame vs CJ frame motor placement - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-20-2007, 11:35 AM
JerseyWheeler
Hello All,
Been a few years since I have been here. Looking to get back into the swing of things.
Just picked up a YJ frame and want to know where the motor mounts are in comparison to a cj frame. I assume the YJ had a 6cyl and there are mounted welded to the frame. Are those mounts in the same position as a cj frame or moved forward or Back?
Also, how much wider is the yj frame according to the cj frame.
post #2 of (permalink) Old 11-20-2007, 11:50 AM
post #3 of (permalink) Old 11-20-2007, 09:38 PM
jdoggmoney's Avatar
Try and figure out for sure if your donor vehicle had the six. Maybe with the VIN number. If so, don't worry about it, unless you are planning on using the CJ mounts on the YJ frame. The engine appears to sit in the same place in relation to the tub. Also, for what it's worth. I think the YJ motor mount design is better and easier to get at for sure. The catch is finding the cast mounts for the block.
I used the pas side YJ (6 cyl) mount but had to fab a driver's side to work with the header. I could get a quick measure ment for the pas side tomorrow if you need it.
Is this the only hammer you've got?
jdoggmoney is offline
post #4 of (permalink) Old 11-21-2007, 06:53 AM
JerseyWheeler
Thanks for the info. I'll give you a little info as to what I am planning. I currently have a cj7 frame with a chevy 305/th400/d20 twin stick. I have the 4wd hardware motor mounts and headers.
I picked up a YJ frame only. I plan on putting all of my drivetrain in the frame and creating a single seat buggy. I am going to build the cage directly to the frame with one seat behind the tranny. Will be running full hydraulic steering obviously.
Going by what you are saying that the motor placement is in the same place with a straight six/yj compared to my cj mounts I should be able to use the stock welded in mounts and my mounts on my v8 should sit on top. I took a quick and I mean quick measurement this morning in the dark and I seem to think it will sit 2" further back in the frame.
I don't have an issue with this other than my rear shaft is already short with wagoneer front springs, which move the axle back 2".
I am told that cherokee springs are offset by 4"... If I can varify this than it will only help my driveshaft issue.
