locking hub questions - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-13-2007, 08:27 PM Thread Starter
newguyJD's Avatar
Question locking hub questions
Howdy! I'm the new guy here (hence the username) My wife just bought me a 73 CJ5 for an anaversery present, and I'v got a few questions about it in general. But first I would like to ask about the locking hubs that are on it. I'm new to jeeps so I wont be embarresed by simple answeres to complicated questions. The hubs on my jeep have the label "Cuttless" on them.Have any of you heard of this brand, and if so are they any good?do they need periodic rebuilding, if so is there a kit available? Also I was told by the guy that sold the jeep to my wife that this model had no emergency brake. I find this hard to beleave but don't know for sure. I wanted it to tinker with, so I don't mind installing one.
Thanks in advance I'll be asking alot more questions in the future
JD
newguyJD is offline
post #2 of (permalink) Old 11-14-2007, 07:00 AM
Welcome to the board, and to the world of Jeeping! You're in for a fun ride.
I never heard of Cutless hubs. Post a picture of them. They might be a relable of a more common brand that we'll recognize. (No digital camer? There's your Christmas present. You're going to need to post a lot of pictures.)
Yes, it did have a parking brake. My '64 had an L-shaped handle that came out from under the speedometer. You pulled it to engage the brake and turned it 90 degrees clockwise and pushed it back to release. Later Jeeps got a generic foot pedal on the left with a little T-handle release, but I don't think those started until a major changeover in '75 or '76.
B. Dash Fabrication
Jim_Lou is offline
post #3 of (permalink) Old 11-14-2007, 07:59 AM Thread Starter
newguyJD's Avatar
Thanks, I'll get a Pic on the way asap.(probably saturday night) Where is the best place to find a stock parking break like the one you discribed on yours?
JD
newguyJD is offline
post #4 of (permalink) Old 11-14-2007, 09:18 AM
MTPockets's Avatar
Cutlass hubs are old school! I was looking at an FC170 a few years back that had them. Parts will be hard to find as I believe that they are no longer made. Best off replacing them with new hubs.
Here is some info:
http://www.willystech.com/wt/Hubs/cu...cutlasshub.htm
Scott
"The devil is red, but his money is green."
MTPockets is offline
post #5 of (permalink) Old 11-14-2007, 09:37 AM Thread Starter
newguyJD's Avatar
Thumbs up
that was what I was looking for!!!
I tried to link to the breakdown views but I guess even the web site is too old. However the removal, inspection and installation procedures will help alot. I have had one of them apart and the nylon part is good and in one peace. The ones on my cj5 look like a cross between the 2 layout diagrams at the bottom of the web page. I don't need a tool to lock and unlock like the one on top, but the body is the same. I have a knob like the one on the bottom. The inside looks pretty sturdy and simple I just need to replace the seals probably, and that will be easier now. The one on the driver side seems to be out of sync with the 2 and 4 wheel markings, but I think I can figger that out as well. Thanks for the link!
JD
newguyJD is offline
post #6 of (permalink) Old 11-14-2007, 10:49 AM
JeepDawg's Avatar
Welcome Newguy....it helps to put more info in your profile....like what part of the country you are in....you never know, there might be a fellow jeeper right around the corner....
As for parts...I think Krage Motorsports is the best source for stock CJ parts.
And kudos to your wife....she sounds like a keeper....and I'm a firm believer in keeping the wife part of the jeep experience....it makes it easier to get additional retrofit funds approved.
AKA DDawg16
D44 Flat top in progress...
Link to my Frame up Restore
JeepDawg is offline
post #7 of (permalink) Old 11-14-2007, 12:01 PM
desprado227
Smile no good
the hubs that u have on thar r no longer made they went out in the early 90s and they were junk then get a set of warn hubs and be dun with it they will be the best choice for what u r running congrats on getting your firs jeep and good luck with the resto .
post #8 of (permalink) Old 11-14-2007, 02:46 PM
Banned
Welcome, and let me say,
I have a '73 CJ-5 with Factory V-8 engine and every possible problem you can think of!
Your Jeep did NOT have an 'Emergency' brake.
However, it DID have a 'Parking Brake'.
Pedal on the left kick panel like most cars of the period had.
The hubs need help!
Your jeep had Warn 'Select-O-Matic' hubs from the factory.
They were lockouts that would allow the wheels to 'Free Wheel' via a 'Sprague' or 'Roller' type clutch inside the hub.
Or could be disengaged all together.
The problem with that design was the 'Cage' for the rollers breaking up.
They are long since out of production also.
It's a very simple process to convert over to Warn Premium type lockout or a Mile Marker Lockout Hub.
I put on two sets of the Warn Premium hubs this sumer, and although a little short on instructions, they can be done in about 30 minutes a side, including cleaning up the hubs and cleaning out the bolt holes.
Be advised, you factory hubs didn't have the usual 2 spindle nut sets you are used to seeing...
You may need to get a couple of spindle nuts (around $6 for bolt nuts and both washers) and you will need a 2-1/16" socket ($8 sockets) to tighten the nuts properly.
If you need any help, let us know, or contact me directly and I'll take pictures so you can see what I'm talking about.
JeepMan is offline
post #9 of (permalink) Old 11-16-2007, 05:36 PM Thread Starter
newguyJD's Avatar
Thanks for the advice. I think I'm going to get a set of the Warn Premium hubs. I talked to Warn today and got a part number of 9062. Is this the same as you installed on yours?the cutless are both still in good condition, but like you have said, Thay aint no spare parts!Thanks
I'll be back later, and hopefully have some pics. Tomorrows opening day of rifle season here in west Tennessee.so it might get put off a little while.
JD
newguyJD is offline
post #10 of (permalink) Old 12-25-2007, 10:16 AM Thread Starter
newguyJD's Avatar
Thumbs up
Well Santa done brought me some new Warn Premium hubs for Christmas. installation looks pretty straight forward(famous last words) but if any one has any suggestions, I'm all ears!
JD
73 CJ5 And 2 Ranchers.
newguyJD is offline
