New Jeep W/Electrical Gremlins - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-28-2007, 08:30 PM Thread Starter
I just purchased a 1980 CJ-7 with a bunch of goodies. 401, Truck Avenger 670, edelbrock intake, optima red top, Dana 60 front narrowed 4" with warn hubs and extra stub shafts, 14 bolt (FF), both with 4.56 gears and detroit lockers, Humvee beadlocks w/run flats, SOA, YJ springs in the rear, torque/traction bar, dana 20 twin stick with tera low and HD output shafts, Ford T-18 Granny Tranny, Custom Roll Cage Tied to frame, custom Flat fenders, tub has been comp cut, aftermarket bucket seats, hard top, hard doors, fiberglass windshield frame, 2 extra Brand New 38" Super swampers... DUI Ignition and the list continues...
Anyway, The Jeep ran when I first checked it out and When I went to pick it up the Previous owner started it and drove onto the dolly. I drove it home and now I can't get a spark... I've checked a few things... The 12 Volt Lead is good, I checked the magnetic pick up that was good, the coil was good... I didn't check the secondary but with everything else being good I Imagine it is good...
Does anybody have any diagrams of the wiring/schematics?
Could this be a ground issue?
Any and all ideas/thoughts are welcomed.
post #2 of (permalink) Old 10-29-2007, 12:05 AM
Carnellc's Avatar
A while back I ran into an issue kinda like yours. I had blown the 15amp fuse. That fuse powered the fuel gauge and the ignition module. Take the ignition out of the picture and yes you guessed it, it won't start. Give it a shot, also try googling wiring schematics. I believe that Autozone has some good ones online. Let me know how it works out!!
Carnell
1986 stock CJ7 rebuilt 4.2L 258 more to come
Carnellc is offline
post #3 of (permalink) Old 10-30-2007, 11:30 AM
Journeyman
DuneCountry's Avatar
I have a hidden ignition cut off switch on my '7
Is it possable that the PO installed one and forgot to tell you?
How did I get sand THERE!
DuneCountry is offline
post #4 of (permalink) Old 10-30-2007, 11:51 AM
JeepDawg's Avatar
LMAU....we are not ignoring you....but I think we need a bit more info.....
What you have is far from stock....as for wiring, you are going to need several manuals....the FSM for the 80CJ...this will cover your chassis wiring....the manual for the year of your engine.....and then what ever else for any non stock items he stuck on the engine.
Ok...it at least sounds like you know something about engines...you checked the obvious.....
!2V on the positive side of the coil...put your meter on the negative side...does it pulse while you crank it? If not, check the dist.....and as noted by Carm...look for a cutout sw.
If the neg side pulses...then you have to have spark out of the coil....
AKA DDawg16
D44 Flat top in progress...
Link to my Frame up Restore
JeepDawg is offline
post #5 of (permalink) Old 10-30-2007, 06:59 PM Thread Starter
I have all of the Jeep manuals, (Jeep/Cherokee,wagoneer/etc)... I'm not worried about the Jeep wiring etc... I tried googling GM HEI schematics... but I didn't get too much.
I'm thinking the Module itself is faulty...
post #6 of (permalink) Old 10-30-2007, 07:12 PM
Carnellc's Avatar
I was told that the modules don't go bad that often. I bought a new one for myself before I discovered that I had blown the fuse. The one I pulled out of my jeep has been there since 86 and come to find out, it was working. Some part stores will run a test on it. Try that before you buy a new one.
Carnell
Carnellc is offline
post #7 of (permalink) Old 10-30-2007, 10:06 PM
Journeyman
towman_tim's Avatar
If it does have a HEI: Make sure the power is plugged into the correct terminal not on the tach side, check that you have 12v there!!!! if you do have 12v there with the key on then you have no cut-out!!!!! still no fire try the module if it's not the problem save it and keep it with you because they do go bad!!!!!
Let us know!!!!!
Tim
Why is it that after you get stuck everyone helps you out then tries to make it though the same spot???
85 CJ-7 /258/Hei/4" lift/33"x12.50 Baja claws/4.10 gears/tera-low/ F-Det, R-Spool / Lots O Goodies
03 TJ 4" lift 33" tires more mods to go !!!!!!!
towman_tim is offline
post #8 of (permalink) Old 10-31-2007, 06:12 PM Thread Starter
I have 12 volts into the distributor, the magnetic pick up coil is good etc. Everything checks out and seems to be good, I didn't check the secondary... I figured if everything is good it would be doubtful that the secondary would be bad. I need to check the grounds etc... There isn't a kill switch... I'm figuring the Module... the previous owner said 5 years ago he had to replace the module... I'll keep you all posted, I don't have time to check things over until I get back from being out at sea.
Until then I'll be search for other reasons/ideas.
post #9 of (permalink) Old 10-31-2007, 06:23 PM
Carnellc's Avatar
Can't wait to see what you find.
What Ship are you on?
Carnellc is offline
post #10 of (permalink) Old 11-01-2007, 09:24 PM
Journeyman
towman_tim's Avatar
Ships = TARGETS
Yep i was a Bubble Head USS WHALE '92 till Decom..
Still think module !!!!!!
Tim
