95 wrangler clutch problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-08-2007, 10:31 AM Thread Starter
I'm right out of ideas on this new fangled jeep stuff. Is there any kind of adjustment on a hydraulic clutch? The symptoms are: no clutch until the pedal almost hits the floor. If I sit at a stop light with the clutch engaged the jeep will start to creep forward after a few moments. The slave cylinder has been bled which helped some. The clutch is supposed to be fairly new. Any ideas?
It's my son's jeep and he drives it fine, just takes it out of gear when stopping.
Brent & Sons
49-CJ3A, 63-CJ5
New_Toyz is offline
post #2 of (permalink) Old 10-08-2007, 10:49 AM
If it's like my old CJ-7 there is an adjusting rod on the clutch linkage. If I remember correctly, the adjustment was on the rod that goes from the clutch to the rest of the linkage. I'm sure there is a proper name for the rod, but mine had a threaded end with an adjusting nut. It was about 4-6" long and was easily adjusted. Here again, I'm speaking from memory of doing the adjustment about 8-10 years ago. It was pretty easy to get to from underneath. I sprayed mine with PBBlaster before trying to turn it. Good luck. Hopefully someone with a better memory or better knowledge will chime in soon.
upalittle is offline
post #3 of (permalink) Old 10-08-2007, 11:00 AM
If the clutch slowly engages when the pedal is held flat on the floor, fluid is escaping from the pressurized part of the system. There are only two possibilities; an external leak which will leave drops on the ground and require occasional replenishment, and an internal leak past the seal in the master cylinder and into the reservior. I suspect that the latter is your problem. Fortunately master cylinders are neither expensive nor difficult to rebuild.
B. Dash Fabrication
Jim_Lou is offline
post #4 of (permalink) Old 10-08-2007, 08:54 PM
Rio_Grande's Avatar
On a 95 there is no adjustment on the slave. it is a "Closed" system like the tj's My experience with that type of clutch is that the hose leaks at the slave or and the master cylinder. The unit is easily replaced. You can also replace the hose between the two by driving out the pins that hold the tube onto the ends.
Ya only go around once, best to enjoy it the first trip.
Rio_Grande is offline
