spedo gauge lighting issues - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-06-2007, 12:58 AM Thread Starter
Carnellc's Avatar
Last week my 86 CJ7 fuel gauge gave up and took my temp gauge with it. After some long troubleshooting I found that it keeps blowing a 15 amp fuse. I have both gauges on order but now I don't have any gauge back lighting when I have the head lights on. The gauge lights are tied into a 3amp fuse and it's not blown.
Any Ideas?????
Carnellc is offline
post #2 of (permalink) Old 10-06-2007, 07:48 AM
I'm into this myself. All of the lamps with the exception of the turn signals get their grounds from the circular clip? that holds the socket into the gauge cluster. The bulb fits into the socket with it's ground-the brass part of the bulb's base-up against this clip. In turn the speedo gauge cluster has to have a good ground that I think it picks up from it's four mounting ears. Quite possibly you're loosing a ground at one point or the way this thing is designed maybe many places. Check for 12v at the orange wires with the parking lights on and a known good ground. Good Luck.
Today's mighty oak is just yesterday's nut that held its ground!
JimmyZ is offline
post #3 of (permalink) Old 10-06-2007, 08:23 AM Thread Starter
Carnellc's Avatar
Wow...
now I wish I had a small head so I could fit it under the dash. Thanks for the info, I'll give it a shot when I get back later today,
Carnell
Carnellc is offline
post #4 of (permalink) Old 10-07-2007, 05:40 PM
Journeyman
FNjeep's Avatar
know exactly what you mean, I'm replacing all my gauges and I ended up taking out the drivers seat and center console. you have to be a contortionist to get under there.
FNjeep is offline
post #5 of (permalink) Old 10-08-2007, 05:26 AM
Or you can get some really long bolts on the ends and remove all the bolts and pull the dash out a bit and get at it from the top. Down side is trying to get all those Torx bolts out without destroying them.
Do the rest of the lights on the dash work?
If you have a bad ground, that could be why your blowing fuses. You may not need new gauges if a ground is the problem. Without a ground the regulator in the gauges dont work and supply full current to you sending units like the fuel sensor and temp sensor. If your fuel tank was full and your sending unit is a little out of adjustment then that's almost like a dead short.
John_Strenk is offline
