tailgate ? 1990 wrangler - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-21-2007, 05:01 PM Thread Starter
Novice
i cant figure out how to get the lock out of my tailgate
I bought it with no key i took it to a locksmith but he couldnt get it open he said to remove the lock and bring it in but i cant get to all the bolts to remove the cover to get to the lock can anyone help me? thanks in advance
fep4 is offline
post #2 of (permalink) Old 07-21-2007, 05:46 PM
Rio_Grande's Avatar
Got a photo? The only locks I am aware of on those years is a lugnut with a key. If that is what it is weld a nut to the top of it and throw it away when you get it off. If you really want to keep it then go by the dealership and they can sell you a overpriced key. I remove them all the time with a lock removal tool. They are expensive You drive it onto the outside and take a impact to it, but I remove around a set or two of the locks a week with no keys so it was a reasonable investment for me.
Jeff
Ya only go around once, best to enjoy it the first trip.
Rio_Grande is offline
post #3 of (permalink) Old 07-22-2007, 12:38 PM
jeeperjohn's Avatar
Not many options here. You might be able to remove the screws that you can get to and use a pair of needle nosed vice grips to loosen the screws on the side of the cover enough to be able to get access rods inside without bending the cover up too bad. (I think there are only two screws on the side of the cover.) If you can get to it, now you will have to disconnect the rod from the lock cylinder and push it up or down to unlock the latch. If that does not work, next I would put as large of a flat blade screw driver into the key opening as I could get in and attempt to force it to turn. Just don't get too crazy or you might damage the hole in the tailgate that the tumbler fits in. If that fails, the next step is to drill out the center of the lock tumbler. I would guess a 3/8 or maybe a 1/2" drill bit would do it. The idea here is open the key side up enough to get the pins to fall out of the tumbler. I don't know if you will be able to remove the tailgate hinges and turn the tailgate to gain access to the mount bolts for the bracket on the drivers fender that the latch grabs on to. If it is possible, the bracket will come off with the tailgate and you could access the cover bolts.
Political Correctness - Because people can't handle the Truth
jeeperjohn is offline
post #4 of (permalink) Old 07-31-2007, 10:04 PM Thread Starter
Novice
thanks for the replys
i drilled the lock center out
it still wont open
i ran outta time to mess with it
i will try to drill it out further later on
fep4 is offline
