Jeep stumbling to a start. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-05-2007, 03:54 AM Thread Starter
Rio_Grande's Avatar
As most know I have a 97 tj. Recently when I start it it wants to stumble to a start. It is as if I have to keep cranking even after it starts to take off or it won't start. I have tried FI cleaner, I will pull the throtel body and clean it up, I even cleaned the K&N filter. I thought the filter was the problem cause it was super dirty, but there was no change after a good cleaning..
Any Ideas?? No codes or running rough after it is running just on start up.
Jeff
Ya only go around once, best to enjoy it the first trip.
Rio_Grande is offline
post #2 of (permalink) Old 07-05-2007, 07:54 AM
When the engine is stone cold, spray in a little starting fluid, and see if it starts right up... smoothly. If so, then it's a fuel pump issue. Check the fuel pressure. If it stumbles on the starting fluid, it's that pesky CPS issue. You mention the K&N, have you cleaned/replaced the manifold sensor?
post #3 of (permalink) Old 07-05-2007, 01:20 PM Thread Starter
Rio_Grande's Avatar
Not that it couldn't be the problem, but it got a new pump, coil, cps, cam position sensor, cap, rotor, and plug wires within the last 1000 mi. I have never replaced the manifold sensor,, Would have to look that one up.
I had a few things last year that pointed to the anti nock sensor,, Can't remember why,,,,, I never replaced it.
Jeff
post #4 of (permalink) Old 07-05-2007, 02:45 PM
Crazy Eddie's Avatar
You're still gonna make it to Haspin Saturday aren't you??? Right now it looks like it's gonna be:
Me
You (hopefully)
JBTater
SweetPea
Tater's brother
Brad
Dan
and maybe another guy I kinda know here from town.
Hope everything works out with the jeep and we see you Saturday!
Aaron.
"4 squirrels runnin' on boggers...and they're angry!!!"
Crazy Eddie is offline
post #5 of (permalink) Old 07-05-2007, 04:03 PM Thread Starter
Rio_Grande's Avatar
Oh yea I will be there, It is running just kinda starting funny. Only way I won't be there is if something stupid happens friday night at work, then I would just be late...
What time are we going!!!
post #6 of (permalink) Old 07-05-2007, 07:26 PM
Just don't fall into the trap if the part's "new" then it's got to be good....
post #7 of (permalink) Old 07-10-2007, 10:16 PM
Sawdust
It's a fule thing.
Check:
Choke
Fuel filter
Fuel pressure
Vacum
Any thing that has to do with FUEL.
post #8 of (permalink) Old 07-10-2007, 10:21 PM
Sounds like the idle air motor. Does it start up and stay at base idle? It should rev up to 1000/1200rpm cold and come back to base idle in 15/30 seconds after startup. If not it is more than likely the idle motor. Might respond to cleaning.
mopar4ever is offline
post #9 of (permalink) Old 07-10-2007, 10:45 PM Thread Starter
Rio_Grande's Avatar
Intrestingly enough, It dosen't idle up just stumbles to a start. Today the battery was low and it didn't want to start until I gave it fuel. I am thinking gunk in the TB or Maybee the idle air control. I will clean verything up then see whare we are.
post #10 of (permalink) Old 07-11-2007, 01:19 AM
Since you are saying it starts hard, but not complaining of a misfire or dead cylinder, look for something that affects ALL cylinders.
Find any vacuum leaks - get it running then spray a BURNABLE carb cleaner or starting fluid around anywhere there may be a vacuum leak. If you get an RPM change, you found it.
Having it start better with fuel can mean it's a lean problem. But adding fuel also lowers plug voltage requirements temporarily, making it easier to start with a weak ignition - and fooling you into thinking it's fuel. Don't rule out a weak ignition.
IAC problem would make it difficult to keep running, not difficult to start.
Look at the spark at the plug end of a plug wire - it should be a thin bright blue "snap." Red or yellow indicates low voltage.
Push the coil wire back in the terminals - both ends.
Replace the coil wire with a known good one. (New doesn't always mean good!)
Clean the top of the coil around the coil's tower.
Look closely at the coil wire where it touches ANYTHING - even a vacuum hose. Look at it close for a grayish spot - where the spark is jumping out to something else. Vacuum hoses can be conductive - especially dirty ones.
RRich is offline
