I would like a GOOD GOUND for my Alternator - Page 4 - Off-Road Forums & Discussion Groups
post #31 of (permalink) Old 06-28-2007, 10:56 AM
I'm calm. I took my pill and I have taz on ignore, so I'm fine as frog hair...
Soft top zippers!
Wish you could get them in brass so they don't corrode up or like the plastic ones loose teeth when they get a couple of years on them!
I've abandoned soft tops, I have a bikini top and a hard top or tarp for winter...
Junk Yard Genius is offline
post #32 of (permalink) Old 06-28-2007, 11:00 AM
I'll throw taz a bone, I hate to have him ranting and raving without knowing what he's talking about again...
Here is a pretty good definition of RMS,
Again, it's AC voltage and has nothing to do with wiring a jeep...
http://www.ece.unb.ca/tervo/ee2791/vrms.htm
post #33 of (permalink) Old 06-28-2007, 11:16 AM
Official Curmudgeon
CJ7Taz's Avatar
Quote:
Originally Posted by RRich View Post
For what you want from me - please hold your breath!
That’s what I thought your reply would be.
I asked you to support your claim that the wire size current charts were bogus. They ain’t, you can’t answer.
I asked you if Ohm’s law is different for AC than it is for DC. It ain’t, you can’t answer.
I asked you what the RMS voltage value has to do with DC having more drop than AC. It don’t, you can’t answer.
I asked you to explain your argument for that do-nothing diode in jyg’s stealth ignition module having some purpose. It has none, you can’t answer.
I asked you for an apology for your malicious act of bringing my family into this thread and being wrong about it, either intentionally or otherwise.
I didn’t think you would apologize. I’d already put you in the same category with people of your type like Hilary and Rosie O’Donnell , to other people that aren’t man enough to apologize either. Their both liberals like you too and neither one of them is very bright either.
Quit spouting you BS on this board trying to be somebody and you’ll get no trouble from me.
CJ7Taz is offline
post #34 of (permalink) Old 06-28-2007, 11:50 AM
Official Curmudgeon
CJ7Taz's Avatar
I answered, “e. None of the above.”
I disagree with their statement, “If you said "b.", you were correct for a sinusoidal waveform, but the full definition of V RMS is much more general.” That’s not the definition just how to derive the value for a sinusoidal waveform.
The RMS voltage is used to figure the power available.
Power in Watts is P=IE (the voltage times the current.)
This can be converted to a function of the voltage and the resistance by the use of Ohm’s law.
E=IR transforms to I=E/R, so P is now equal to E squared/R.
There isn’t a function to provide the square of the wave form so it is necessary to take lots of very small samples of one cycle of the waveform, square them and then divide by the number of samples. This gives a valid value of V squared for the power equation. The square root of that value is the RMS (root mean squared) value of V. The voltage value given as coming out of a wall socket is already stated as the RMS value.
The question is what this has to do with Rich’s statement:
If you understood AC vs. DC in other than sexual terms, you'd understand why DC has more drop than AC. Clue - Does RMS mean anything to you?
You only proclaimed;
Quote:
Originally Posted by Junk Yard Genius View Post
Anyway, RMS is the correct answer...
You never told us what the question was. It may well be the answer to some question but not to anything we have discussed here.
CJ7Taz is offline
post #35 of (permalink) Old 06-28-2007, 11:52 AM
"""""I asked you to support your claim that the wire size current charts were bogus. They ain’t, you can’t answer."""""
I pointed out that the charts don't take in consideration for length. You said they show limits as to possible current carrying capability - but you ducked the question of for "how far."
Your chart says at least you said it does:
"""""10ga is good for 30 amps"""""
"""""I said 6 or he might get by with 8 for an 85 amp alternator."""""
OVERKILL! Especially for the ground.
"""""I asked you if Ohm’s law is different for AC than it is for DC. It ain’t, you can’t answer."""""
You answered it yourself, if you want to argue with yourself then go ahead!
"""""I asked you what the RMS voltage value has to do with DC having more drop than AC. It don’t, you can’t answer."""""
Your statement that DC carries long distances better with less loss than AC - pertaining to the comments about Edison - you said because it's easier to step up the voltage using transformers with AC, - that's one reason - you were correct there, But you avoided the fact that AC has less line loss than DC. I said it was because of RMS. If you actually knew anything about electricity, you would have known about RMS and how it affects heat losses.
Does every little thing have to be spelled out in detail to you? You say you are an electric train expert, doesn't your toy train manual cover that? Is Lionel still in business?
Notice on the thread JYG just posted that explains RMS. Notice at the bottom it talks about heating of a resistive value to measure actual RMS values.
I asked you why the ground to the alternator has more current than the alternator's output and requires a much heavier wire than the standard 10 GA almost all carmakers use. You ducked the question - as usual. By your information there should be millions of cars stuck all over the world with dead batteries!
"""""I asked you to explain your argument for that do-nothing diode in jyg’s stealth ignition module having some purpose. It has none, you can’t answer."""""
That was an entirely different thread - ancient history - are you still fretting over that? You certainly need to get a life!
Since JYG wasn't going to explain it to someone like you, I was not going to either.
"""""I asked you for an apology for your malicious act of bringing my family into this thread and being wrong about it, either intentionally or otherwise."""""
YOU are the one that brought in your family in an attempt to hide behind them, hoping to pretend you are "normal" and not in your grandmother's basement. I never said anything about your "family" untill you did.
An apology -- I told you I would, just hold your breath till I do!
RRich is offline
post #36 of (permalink) Old 06-28-2007, 12:40 PM
thorjeep's Avatar
Rrich, time to get outta there before you get hurt. This is nowhere for a child to be in the middle of such heavy information flying around. You are not contributing, just being inflammatory.
Taz and Jyg, this is really interesting, though over my head. If I could make a suggestion: It looks from this side he said/he said; could we get more links supporting your positions instead of quoting each other?
Scott
1985 CJ7 T.H.O.R
"He brought me up out of the pit of destruction, out of the miry clay, And He set my feet upon a rock making my footsteps firm."
-Psalm 40:2
thorjeep is offline
post #37 of (permalink) Old 06-28-2007, 12:54 PM
Wow, this is good stuff. I just spent my whole lunch catching up.
John_Strenk is offline
post #38 of (permalink) Old 06-28-2007, 05:00 PM
I'm not into it with taz, I have him on ignore...
All I see is what people quote from him.
I have no idea what his arguments are, but since he's [u]Always[/b] wrong, I just figure he's dead wrong on this too.
It's not really a stretch.
This is the guy that thinks a switched DC circuit makes it AC and adding dedicated ground wires is a "BAD" idea...
Anyway, what is the general consensus on soft top zippers?
I never heard...
post #39 of (permalink) Old 06-28-2007, 05:38 PM
I was just skimming over the stuff trying to get to the bottom of the page and happened upon this...
I don't know who is quoting whom here, and frankly, I don't care.
Since taz is on ignore, I don't see his posts...
Until now I wasn't aware there were any questions about the diode in my version of John Strenks 'Stealth HEI'.
I knew dale and taz wouldn't understand, because neither can read a schematic and dale has problems with my simple diagrams, but I wasn't aware anyone else had a problem with it...
If there is any doubt what that diode is there for, or what it does, let me know and I'll explain, and if taz or dale gets into it, maybe someone like John Strenk will be kind enough to mediate and/or offer a 'Neutral' opinion/explanation of the diode's purpose.
Honestly, I had no idea that little diode would be such a source of so much amusement to taz and dale. Glad they had something to talk about!
Their musings between themselves probably kept them from pranging on or insulting some new guy or arguing over nothing with one of the members that actually knows what they are doing most of the time... So it's OK with me.
Note to John Strenk,
John, I don't deliberately misspell your name! I'm sorry, but I just can't remember how you name is spelled! I'm stupid that way sometimes...
I can write it 30 times in a sentence, and still screw it up!
It's not intentional, and I'm sorry, but I know I'll do it over and over again...
Aaron.
post #40 of (permalink) Old 06-28-2007, 06:06 PM
Journeyman
Question
Wow! That was fun. Dan
jeepdanut is offline
