jeeperjohn, I use MS paint or one of those things that have been in my computer since Win '95.
Nothing to them really.
I guess taz is blowing off again...
I have him on the ignore list so my life is easier than the rest of you have it
Some FACTS,
If you have over a 100 amp alternator, and you think you will be draining your vehicle at full capacity, you may want to use a 2 Gauge wire from the alternator 'Batt' terminal to the solenoid...
A 2 gauge wire will transmit over 100 Continuous amps with out overheating.
(Keep in mind your alternator usually idles at under 10 amps for most of it's life, so this would be a HUGE waste of time and money...)
If you are using any alternator on planet earth smaller than the one needed to launch the space shuttle,
(like a Delco SI series that most of us are running)
10 Ga. wire us usually enough.
10 Ga. will handle over 30 amps continuous, and will handle short term loads over 50 amps...
If you have one of the alternators that will power a small city, Like some of the 'Electric Everything' vehicles use, it's probably a CS series...
And if you are loading it until the amp gauge smokes and screams at you...
In that case I'd use an 8 or 6 gauge wire.
I weld and jump completely dead vehicles with 4 gauge wire, so that should tell you something right there...
If you have an average vehicle load, as in the usual, lights, wipers, ignition, ect...
You alternator will only be supplying about 30 to 40 amps to the vehicle.
That's 8 gauge wire with no heating...
Since CJ's don't have electric defrosters, or 'Power Everything' (I'd settle for 'Power Anything!) your alternator is going to 'Idle' at about 10 amps.
That's usually what it takes to power the ignition, brake lights/turn signals, fuel injectors and keep the battery topped off with the A/C running.
MORE FACTS!
The first fact is your battery supplies the current for you devices, not the alternator.
The alternator is a 'Pump' that fills the battery back up after usage, so the entire load (and in actuality, the battery is over charged when the vehicle is running), so virtually none of the vehicle load is coming from the alternator
Here is the Brown & Sharp used by everyone for low voltage DC wiring...
10 Ga./ 32.5 amps continuous with out heating from resistance.
8 Ga./ 46.1 amps continuous.
6 Ga./ 65.2 amps continuous.
4 Ga./ 92.3 amps continuous.
2 Ga./ 131 amps continuous.
0 Ga. (also expresses as 1/0) 185 amps continuous.
00 Ga. (also expressed as 2/0) 220 amps continuous.
000 Ga. (also expressed as 3/0) 262 amps continuous.
0000 Ga. (also expressed as 4/0) 312 amps continuous.
4 Ga. is usually plenty to get a stock engine started if the battery/starter run is kept short.
(and I've never seen a 'Long' run on a SWB Jeep even when the battery was in the extreme rear of the vehicle!)
Now, this information pertains to virgin copper wire, not alloyed wire used in most 'Battery Cables' and 'Automotive Wiring'...
Welding cable is virgin copper for no other reason than welders won't put up with nonsense.
Remember, this wire will transmit much more amperage, these are the ratings at which the wire will NOT heat up.
If you transmit more amperage through the wire, it will pass, but the wire will begin to heat.
For the short duration you are cranking the engine, the 4 Ga. wire is plenty...
Now, for a bit of information...
Our electric air compressors need a 70 Amp relay to stay alive...
We feed that 70 amp relay with an 8 Ga. wire.
This seems like a contradiction in the scale, but it's not, and here is why...
First,
The compressor will require about 68 amps to get started when pulling against a pressurize line.
The compressor kicks on at 135 PSI, so the piston/motor has to overcome that 135 PSI from a dead stop.
That will spike amperage required to get things started MOMENTARILY to around 68 to 70 amps.
Within a half second the motor is turning quickly, and the amperage required drops to about 30 amps.
Same principal with your starter motor on your jeep engine...
A Hard 'grunt' to get things started moving, then amp requirement drops way off...
That's why you can start most vehicles with a lawn mower battery with no problem...
That relay and 8 gauge wire, and compressor are bringing a 5 gallon tank up to 150 PSI in about 4 minutes.
After the initial amperage spike, the requirement drops off to about 30 amps, and the 8 Ga. wire is more than capable of doing 30 amps all day!
In fact, I know people that have used our air compressor relays, sockets and harnesses as starter relays in a pinch, and I know of one guy that has two in parallel starting his vehicle for over a year now!
That's a 140 amp capacity starting a vehicle in Indiana cold with what are basically driving light relays...
So, if you find yourselves buying into 'taz crap', just throw us a line and we'll be glad to help you with correct information...
