Installing a locker- roll pin removal - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-21-2007, 10:14 AM Thread Starter
Official Historian
WILL's Avatar
Ok, this is probably a beginner question but what do you use to remove a roll pin from a differential cross shaft? A regular punch isn't long enough. This is on a dana 30 and 35. I was hoping my dana 35 would have a bolt but since it is pre-c-clip, it has a roll pin. Also a bit of trivia... my dana 35 has a pipe plug in the cover so they aren't all rubber plugs.
WILL is offline
post #2 of (permalink) Old 06-21-2007, 10:39 AM
mbalbritton's Avatar
Quote:
anything that is the right Diameter and long enough.... seriously!
Sure it's a D35? Can't say I've seen them with a pipe plug.
The belief in a supernatural source of evil is not necessary; men alone are quite capable of every wickedness. - Joseph Conrad
mbalbritton is offline
post #3 of (permalink) Old 06-21-2007, 12:25 PM
mach2_nh's Avatar
Ya the 35 on my 88 YJ was a pipe plug to. MUCH better setup. But i dont need to tell you that.
88 YJ SOA2.5" 2"BDY Locked F/R Chevy 4.3 NVG241OR 4.56's 36x12.50
mach2_nh is offline
post #4 of (permalink) Old 06-21-2007, 03:37 PM
SilentBob2's Avatar
I think I ended up using an allen wrench to nock it through !!!!!
SilentBob2 is offline
post #5 of (permalink) Old 06-21-2007, 03:51 PM
Rio_Grande's Avatar
I have a set of drift punches that are longer than average, they work, but I also have used an allen wrench.
Ya only go around once, best to enjoy it the first trip.
Rio_Grande is offline
post #6 of (permalink) Old 06-21-2007, 03:53 PM
Gutter spike?
B. Dash Fabrication
Jim_Lou is offline
post #7 of (permalink) Old 06-21-2007, 04:10 PM Thread Starter
Official Historian
WILL's Avatar
OK. Just didn't want to get part way into this and no be able to continue or go back easily. Anyone know if they can be removed with the carrier still in the housing?
WILL is offline
post #8 of (permalink) Old 06-21-2007, 04:38 PM
Rio_Grande's Avatar
As I recall yes, but it has been quite a while.
post #9 of (permalink) Old 06-21-2007, 10:49 PM
Journeyman
towman_tim's Avatar
Will
knock the carrier out take the ring gear off !!!! i really don't think there is enough clearance for you to assemble the locker inside the houseing!!!!!!! plus this way you can inspect the carrier bearings!!!!!
Just a thought take it as you will !!!!!!!
Tim
Why is it that after you get stuck everyone helps you out then tries to make it though the same spot???
85 CJ-7 /258/Hei/4" lift/33"x12.50 Baja claws/4.10 gears/tera-low/ F-Det, R-Spool / Lots O Goodies
03 TJ 4" lift 33" tires more mods to go !!!!!!!
towman_tim is offline
post #10 of (permalink) Old 06-22-2007, 04:02 PM Thread Starter
Official Historian
WILL's Avatar
I made a drift out of a long allen wrench last night. It worked great for moving the roll pin. I did have to pull the bearing caps (and one axle) but didn't have to remove the carrier. I'll get around to the front another time. The lockright went together very easy.
I have 3.07 gears... the ring gear is plenty far out of the way. lol
WILL is offline
