Weber 32/36 linkage won't fit - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-18-2007, 04:37 PM Thread Starter
Newbie
Hi,
trying to install a weber 32/36 kit (k491) on my 1980 Jeep Cj7 (151-engine) i discovered that the linkage causes some problems and is not just a bolt-on as promised. Maybe you guys with expierence on converting webers can help me out.
As you can see on the attached pictures the small rod between the bellcrank on the manifold an the throttle lever is too long an positioned either to far away or to close to both of the ball-type connections on the lever. So if connected the whole assembly doesen't move freely and tends to fall apart again.
What are my options? I tried to get a shorter rod between bellcrank and throttle lever, but it was not available here. Anyway. in this case the lever would still be either to far away or to close to both of the ball type connections.
Convert to a universal linkage? I'm not sure there is enough clearance between the valve cover and the carb for that.
Anything else?
Thanks in advance
Momo is offline
post #2 of (permalink) Old 06-18-2007, 06:43 PM
Two choices seem obvious: Call who ever said that it was bolt-on and have them tell you how to bolt it on, or fix it yourself, for which I see two choices: Move the bellcrank or adjust the length the link.
It's hard to tell from your pictures, but I think moving the bellcrank would be the better choice. The angles are going to be rather extreme with the bellcrank where it is. Can you move it a little forward and closer to the valve cover?
B. Dash Fabrication
Jim_Lou is offline
post #3 of (permalink) Old 06-18-2007, 07:01 PM Thread Starter
Newbie
I 've been talking to the guys who said it was a bolt-on for three months now. Not very helpful. Moving the bellcrank would mean to machine a thread into the intake mainfold, which probably has to come off for that. Something i wanted to avoid.
Momo is offline
post #4 of (permalink) Old 06-18-2007, 07:51 PM
Betcha a nickel that's not necessary. Make a plate that will bolt to a couple of bolt holes in the head - the one the bellcrank pivot is in now and another one near by if possible. Then drill a hole in the plate and put the pivot in it. Easy!
(see my signature)
B. Dash Fabrication
Jim_Lou is offline
post #5 of (permalink) Old 06-25-2007, 03:59 PM
79 Corona
Have you contacted Weber directly? I'd make sure what they sent you IS the correct conversion kit. The carbs are the same, but have different adapters and other hardware to make it work on your model. Apparently the K490 will work as well.
