5-Speed to 6-Speed Conversion - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-17-2007, 01:14 PM Thread Starter
Here's another TJ question. One of my buddies rolled his 2005 TJ 4.0L in Tennessee and since he bought it used w/o a loan, he didn't have collision insurance on it, so he's parting out what wasn't damaged. One of those few things not damaged was the 6-speed tranny, clutch, and shifter. I wanted to know if that would fit in my 1997 TJ 4.0L without any modifications, or if there are, how much has to be modified. Thanks guys!
FiveSpeedWrangler is offline
post #2 of (permalink) Old 05-17-2007, 01:55 PM
JeepnGreg's Avatar
i dont know for sure...but if its also a 4.0L....it should work as long as you get the bell housing with it.....might want to get the clutch slave cylinder while you are at it....
i dont think there would be a difference with the transmission output..but i'd check to make sure the splines are the same so you can re-use the t-case....
Doesn't-have-a-Jeep'n Greg
VISIT MY GUN STORE: http://www.AmericasBasement.com
JeepnGreg is offline
post #3 of (permalink) Old 05-17-2007, 04:32 PM
Rio_Grande's Avatar
If it were me I would buy from the bell back including the shifter and boot, trsanny, t case, whatever is left of the shafts weather dammaged or not and swap it out.
I am a fan of spare parts though. If there was an improvement over the 231 which I don't know if ther was in 2005, Great, if it is just the standard 231 then you have a repair box sitting in the shop.
Worst mod I can see is if the shafts are a diffrent length due to the diffrent tranny, worst case have them cut or lengthened, that is a minimal mod, If the t case is diffrent and you can swap it in it is an upgrade,. but I think that has a 231 in it. There are mods in every swap even same for same,, but you are swaping within the same body, engine style,,, I think it would be relativly simple provided everything is in working order.
What is wrong with the 5 speed?
Ya only go around once, best to enjoy it the first trip.
Rio_Grande is offline
post #4 of (permalink) Old 05-17-2007, 04:41 PM Thread Starter
Nothing's wrong with mine other than I think a syncronizer is going bad for reverse gear. Mine is the AX-15. I just wanted the 6-speed to have the extra gear.
post #5 of (permalink) Old 05-17-2007, 06:09 PM
Rio_Grande's Avatar
Drain an refill that ax15 with syncromesh and that grind will likely go away. Mine was going out 40000 mi ago. after putting the syncromesh in it was fine until just recently when it started again. I bet if I change the fluid again it would stop for a while. It is a cheap fix for a mispublished service manual that told us to put gl5 in the trannies but in fact gl5 has sulpher in large enough quantity to break down the brass syncros in your ax15 and my ax5. I changed my oil 2x a year from day one and at 60000 mi had syncros start wearing out. Happy,,,,, So much for preventative maintence.
Gl3 is the correct fluid, but the syncromesch is a bit thicker which helps the syncros go back to working with the rest of the gearset.
Intresting...
Would still be a cool swap.
post #6 of (permalink) Old 05-17-2007, 10:52 PM
jeepjunky's Avatar
issue #5 of Jrations has an artical on doing the swap. according to them:
"a jeep with a 4.0 and eather a NV-231 or NV241OR Rock-trac its more or less a bolt in. because the bellhousing is integral with the tras case. its not easily adapted to older units. its rated for 272 lbs-ft of torque."
He wouldnt happen to have a center console (the two cup holder one with the key shut off for the pass airbag?) Id be intorested in buying that.
Good Luck
jeepjunky is offline
post #7 of (permalink) Old 05-18-2007, 12:58 PM Thread Starter
Good Luck
Mine is the NP231, I believe. I haven't seen under a six-speed one yet, so I am not sure about the T-case.
As for the console, it's gone. It was actually cracked in the wreck. He got sideswiped on the freeway and flipped. When he flipped, the jack that he had in the back floorboard flew up and cracked the back of it. Sorry man. He told me that all he has left is what I'm wanting. He's waiting for me to find out if it'll work with mine, otherwise, he already has someone else lined up if it doesn't. The rig was pretty much destroyed, so there was not much to salvage.
post #8 of (permalink) Old 05-20-2007, 07:02 PM
jeepjunky's Avatar
o well, thanks thanks though.
post #9 of (permalink) Old 05-21-2007, 09:43 AM
Official Historian
WILL's Avatar
Quote:
The 6 speed doesn't have a separate bell housing, it is part of the transmission case.
WILL is offline
post #10 of (permalink) Old 05-21-2007, 12:48 PM Thread Starter
Quote:
So basically it will work with what I have now?
