100k maintenance - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-06-2007, 10:43 AM Thread Starter
100k maintenance
the jeep (00TJ, 4.0, nv3550) has 110k miles on it now and i have it torn down to replace the clutch. i have a little time to work on it now, so i am wondering how far down this maintenance/replacement road to go. the engine rear main seal is a no brainer, but i'm not sure where to draw the line, if i want to try to run down every single leak. it also looks like the head gasket is leaking, so that may be on the list too.
the exhaust is about done and i would really like to replace it, but if you have been following some of my other posts, i have been having issues with one of the cat/o2 sensors. i was considering replacing the whole thing, head to tail pipe, but the dual 'mini-cats' seem to be a deal breaker. it seems silly to me to replace the header and cat-back, but leave the old cats.
so far here is what i have definite 'to-do' list:
1-clutch kit (w/pilot and throw out bearing)
2-rear main seal
3-replace old driveline u-joints
4-replace all driveline fluids
i am also trying to think of other upgrade-type changes to make, like relocating the breather to a higher spot for water issues. (btw- i had read a really good write up on that but can't find it now).
so weigh in with your thoughts on what to add to the to-do list.
thanks
shawn
It is amazing what you can accomplish when you are too dumb to know that you can't!
80cj is offline
post #2 of (permalink) Old 05-06-2007, 11:53 AM
JeepDawg's Avatar
You have the right idea.....
At 110K miles, that old 4.0 is just getting into it's prime....you should be able to get another 100k out of her before anything major.
As for the leaking head gasket...I would be willing to bet that it's not the gasket but rather the valve cover. What happens is that oil leaks down from the valve cover, hits the seam between the head and block and 'weeps' around...making it look like the head is leaking.
If not done recently, swap out the fuel filter.
Otherwise, it looks like you got it covered. Just do a good inspection of everything...make sure all the bolts are tights.....and you should be good to go.
AKA DDawg16
D44 Flat top in progress...
Link to my Frame up Restore
JeepDawg is offline
