Trans Problem 88XJ - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-27-2007, 10:46 PM Thread Starter
ImSpanky's Avatar
Trans Problem 88XJ
I posted this on the Mid-Size board to no avail. Now at the risk of getting
slapped for being redundant, I will post this here in hopes of at least a reply.
Any help at all will be greatly appreciated. I believe that the trans is an AW4
Thanks
David
The automatic transmission in my Cherokee has abruptly stopped shifting. It winds out in first gear. It is a 1988
Cherokee Pioneer 4.0l bone stock. This happened while it was being driven. I
have checked the fluid level, it is fine. No obnoxious smell or signs of burning.
The fluid on the stick is bright red. Can anyone point me in the right direction as
far as troubleshooting this situation. It has a Power Selection switch on the
dash. It has been in power mode since I have owned it. I'm not sure what
other information would be needed. Any help would be greatly appreciated.
Thanks
David
ImSpanky is offline
post #2 of (permalink) Old 04-28-2007, 07:11 AM
SilentBob2's Avatar
What tranny does it have???
SilentBob2 is offline
post #3 of (permalink) Old 04-28-2007, 07:38 AM Thread Starter
ImSpanky's Avatar
The tranny is an AW4. I have never had anything quite like this happen before.
David
ImSpanky is offline
post #4 of (permalink) Old 04-29-2007, 02:15 AM
JeepDawg's Avatar
On the right side up under the lip of the lower dash is a yellow rectangular box....THAT is your transmission control module. It 'could' be your problem.
I would first make sure that the connector is plugged in correctly. Next, you might try buying another one from the junk yard. If there is no difference...then it is most likely a problem in the tranny.
AKA DDawg16
D44 Flat top in progress...
Link to my Frame up Restore
JeepDawg is offline
post #5 of (permalink) Old 04-29-2007, 09:14 AM Thread Starter
ImSpanky's Avatar
Thank You JeepDawg. I have done a little research, and found that the TCU
could be part of the problem. Two other areas of interest are the TPS, and the
TVC. There is also an inline fuse and a resistor pack attached to the TCU. I will
check all of these out and see if that helps.
Thanks again for your help JD. When I get it up and running again, I'll let you
know what the problem was.
David
ImSpanky is offline
post #6 of (permalink) Old 04-29-2007, 10:26 AM
"TVC, TPS, TCU . . . . "
It's MUCH better when you push a pedal and move a lever.
B. Dash Fabrication
Jim_Lou is offline
post #7 of (permalink) Old 05-08-2007, 06:05 PM Thread Starter
ImSpanky's Avatar
Well,,, I did a little troubleshooting today and it is definitely the TCU that has gone bad. I unplug it and can manually shift through the gears. So I
spoke to Jesus Chrysler on the phone and was quoted $787.00 for a replacement part. It seems that the part was taken out of production, and the
only one left in the system is located in New Jersey. I paid $800 for the Jeep. I guess its time to start looking in the salvage yards for an 87-90
Cherokee. If I can,t find one in salvage then I guess I have a new motor for the 72CJ.
Dave
ImSpanky is offline
