Shifter hell - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-29-2007, 10:46 AM Thread Starter
86CJ7's Avatar
Shifter hell
I purchased a rebuild steering column with a shifter for my CJ7 and a linkage kit from Ididit. It is installed correctly and shiftes the 904 tranny. The only problem I am having is shifter will not lock into any gear. It is like there is no detent at all. The shifter handle smothly slides from park to low. How can this be fixed?
86CJ7 is offline
post #2 of (permalink) Old 01-29-2007, 11:37 AM
Re: Shifter hell
The first thing I'd do is detach the shifting linkage at the transmission shifting shaft. Then put a pair of locking pliers on the shifting shaft and see if you can feel the detents as you rotate the shaft...
What has Ididit said? Have you contacted them?
post #3 of (permalink) Old 01-29-2007, 12:02 PM Thread Starter
86CJ7's Avatar
Re: Shifter hell
Ididit told me that the detents were in the column. My guess is the column is messed up.
86CJ7 is offline
post #4 of (permalink) Old 01-29-2007, 12:15 PM
Re: Shifter hell
Nope.. the detents are not in the column, they're right. The dentents are on a shifting plate inside the transmission, on top of the valve body. That's why I'm asking you to check the shifting shaft without the column linkage attached.
The detent plate is only peened into the shaft collar. If it's loose, you'll never be able to shift and keep the detent.
post #5 of (permalink) Old 01-30-2007, 06:18 PM Thread Starter
86CJ7's Avatar
Re: Shifter hell
I think you are right LEVE. A local transmission shop confirmed what you just stated. I am going to take it to tham and let them fix it.
86CJ7 is offline
post #6 of (permalink) Old 01-30-2007, 07:31 PM
Re: Shifter hell
Well why not take a couple of hours and do it yourself... it only takes loosening about 24 bolts.
post #7 of (permalink) Old 01-31-2007, 01:27 PM Thread Starter
86CJ7's Avatar
Re: Shifter hell
I was under the impression that the valve body needed to be removed and I have never opened up a tranny before.
86CJ7 is offline
post #8 of (permalink) Old 01-31-2007, 06:01 PM
Re: Shifter hell
The valve body does need to be removed. But that's only 14 bolts. Once you drain the transmission and remove the skidplate, ATF pan, kick down and shift linkage you can then drop the Valve Body. It's not hard, in fact, it's quite easy. The only tool I'd want to have on hand is a 1/4" inch-pound torque wrench to retorque the bolts on re-install.
This is not something you need to be afraid of...
post #9 of (permalink) Old 01-31-2007, 06:05 PM Thread Starter
86CJ7's Avatar
Re: Shifter hell
OK, I think I will give it a shot. Thanks LEVE. I will let you know how it goes.
86CJ7 is offline
post #10 of (permalink) Old 01-31-2007, 06:08 PM
Re: Shifter hell
Let me now if you need pages out of the manual....
