CJ7 1978 Frame vs. 1986 Frame - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-07-2007, 09:51 PM Thread Starter
I want to swap out the from on my 1978 CJ with a 304/Q-tech tranny. How hard would this be using a 1986 frame. Can it be done without welding"?
Cneglia is offline
post #2 of (permalink) Old 01-07-2007, 10:16 PM
Re: CJ7 1978 Frame vs. 1986 Frame
IIRC the back side tub mounts (in front of the rear wheels) are different locations. Yours are further froward than the later frame. Other that that it's the same.
post #3 of (permalink) Old 01-08-2007, 01:07 AM
[ QUOTE ]
Wellll, ifin I recall there's no difference in body mount positions on cj7 frames from at least 76-86. Front shock mounts will be tall mounts instead of short, skid plate bolt pattern may be different depending on what tranny was in the donor frame, brake line brackets at the front wheels might be a bit different, possibly a couple other minor details, but I don't think the body mounts are different.
spook2 is offline
post #4 of (permalink) Old 01-09-2007, 12:21 PM
Journeyman
Aren't the front shock mounts different (NT vs WT)? So if you don't want to weld/fab NT mounts onto a WT frame, then plan on using shocks for a WT (better anyway).
bleoh is offline
post #5 of (permalink) Old 01-09-2007, 04:53 PM
pontiac58's Avatar
I cant say anything about the body mounts, but I not for sure that the front shock mounts are different, and i cant remember for sure but i think the rear shock mounts are in a different spot.
pontiac58 is offline
post #6 of (permalink) Old 01-09-2007, 06:53 PM
[ QUOTE ]
Rear shock mounts are the same. I laid out the only major differences in my post above. I'm on my third frame swap right now ranging from a 1979 to a 1985. The only major difference due to model yeare in the FRAME are the front shock mounts. Any other differences are minor, with the exception of the bolt hole pattern for the skid plate and that is more dependent on what drive train you had rather than what year the frame was/is.
spook2 is offline
post #7 of (permalink) Old 01-09-2007, 08:32 PM
pontiac58's Avatar
[ QUOTE ]
[ QUOTE ]
I still think the rear shock mounts are forward more on the newer frames. When we grafted a 86 frame rail section into my 80, i remember going nutz trying to figure out why my measurements were so far off. Im pretty sure we used the shock mount to get a rough cut. Its been awhile but, i think it was forward like 6 inches or so. Ill be at the yard this weekend and i will have to take a look.
post #8 of (permalink) Old 01-10-2007, 09:29 AM
Journeyman
I just compared my 80 to my 84, measuring from the bolt on the fixed hanger of the rear spring to the shock mount stud and they were both approx. 18" appart.
bleoh is offline
